good or bad combo
pa308
45
hi im new here but what u think about my enigne combo. stock roller block .40 over align honed zero decked torque plate honed. I m using cp lite weight pistons with total seal gapless rings and eagle ibeam rods.A stock crank cut .10 and .10 micro polished journals chamfered oil holes.Gt40 heads with a 5angle valve job and 1.72 cobra rockers.I also have a Z cam.Im using a wingage tray and main girdle with a 7 quart pan. Up top a holley intake, 75 maf, 75throttle body, and 30lb injectors. How much power at the flywheel.Sorry for long post ,i dont have desktop dyno yet.Thanks guys
It seems like that cam and intake are pretty big for those heads. I would think that those heads would like to make power down low where as that intake is VERY strong up top to go along with that cam. Although im not positive, i dont know much about those heads just taking a guess.
i am thinking the same im just ising them to get by im not done building yet but hopefully soon.eventualy im swithching over to afr185 and port matching the intake. i hope to run mid to low 11s
Holley intake and 30lbers r too big for a NA 306, those GT 40 heads r too small. MAF needs to be larger than TB.
I would go with TW 185 cnc'd heads or AFR 185's, Z cam or Comp cam XE282HR and a port matched RPM ll, 24's, 70mm TB and 75mm MAF.
u could hit 350/350 or more @ the RW with the right combo and 10:1 comp.
thanks for the help im running 10.5 compression. my brother ran same engine made 300rwhp at 6000 went 11.90 at 113.only difference was heads he had windsor sr. on the dyno he was running lean up top so wouldnt u need more fuel he never had a tune for it just stock computer
