Just wondering if someone could recommend a good rotating assembly for my 302 build, top-end is gonna be windsor jr's, afm n-41, pro magnum 1.6's, 70mm tb, 76mm maf, 24lb injectors, 190lph fuel pump, still undecided on intake, I found one kit at Flatlander Racing but wondering if there is anything you would recommend over this kit? This is also the only place I've found a rotating assembly for a stock stroke 302, all the others I found were for a 331 or a 347.
The kit has a Pro-Line 5140, or a Pro-Line 4340 forged 3.0 stroke crank, Pro-Line or Skat 4340 h-beam rods, and either SRP or JE forged flat top pistons. The price is 1299.00, does that sound good?
I would like to get the 5140 forged crank (it's 200 dollars less than the 4340 crank), as far as the rods and pistons go, which ones would you recommend, the pro-lines or skat for rods, and srp or the je pistons? Or would you recommend a whole other kit?
Wanting a mostly street car that can also take a little beating at the track if I want it to.
Thanks for your help.
Wanting a mostly street car that can also take a little beating at the track if I want it to.Thanks for your help.
