Got a cam... Opinions?
ironheart1
131
Connecticut
Heya.. Just had my birthday this weekend and my team went to work on making me make my car fast and bought me a cam... I've not heard anything about this that I can remember, so I figured I would post here and get some opinions on it.
Speed Pro Part #CS1177R
Advertised duration: 299 intake/309 exhaust
Duration at .050 in. cam lift: 222 intake/232 exhaust
Gross valve lift: .510 in intake/.534 exhaust
Lobe Seperation: 112 degrees
Peak horsepower rpm: 6,000
Peak torque rpm: 2,750
Power range 2500-6000 - Fair to slightly rough idle
Anyone have any experience with this? I know I should PROBABLY convert to a MAF before I install this and I think I'm going to get heads and an intake as well. Any input at all as to what would work well with this cam?
That's what I was thinking, I at least want to do heads and an intake when I do the cam. When the engine goes boom (something will blow eventually) I'm going to try to go for a DSS 331 as well.
What do you guys think I should think about doing before installing this?
Go with the Maf conversion, check p to v clearance, that cam seems pretty big (powerband wise...seems you have to rev it to get it anywhere but that 331 can't take care of the torque)...is this a daily driver...?...might be a bit "rough" for a daily driver... :shrug:
I have the TFS stage 1, and only the lift is slightly less, with my combo, I am pulling alot more higher power, and about the same bottom end. I think you'll like it for a daily driver.
have you verified this to be a hydraulic roller cam?
hell I wasn't even aware that speed pro made performance cams :shrug:
just some observations...
duration is big, probably will not pass the sniffer (if you have to worry about it)
I would guess that you WILL have piston to valve clearence issues.. you will eigther need new pistons or notch your existing ones.
that cam WILL NOT work with speed density MAF conversion is required
the cams got SLOW ramp rates & a narrow LSA so vac. will be low.. may affect
your power brakes & or HVAC controls.
given your current set up...I'd avoid that cam like the plauge
JMHO
Mike
