SECTION 205-02B: Rear Drive Axle/Differential — Ford 8.8-Inch Ring Gear 2000 Mustang Workshop Manual
IN-VEHICLE REPAIR Procedure revision date: 06/17/1999
Differential Housing Cover
Removal
Raise and support the vehicle. For additional information, refer to Section 100-02.
NOTE: Empty the lubricant into a clean container for reuse.
Remove the differential housing cover (4033).
Remove the 10 bolts and drain the lubricant from the differential housing (4010).
Remove the differential housing cover.
Installation
CAUTION: Make sure the machined surfaces on both the differential housing and the differential housing cover are clean and free of oil before applying the new silicone sealant. To prevent contamination, cover the inside of the rear axle (4001) prior to cleaning the machined surface.
Clean the differential housing and the differential housing cover gasket mating surfaces.
CAUTION: Install the differential housing cover within 15 minutes of applying the silicone, or it will be necessary to remove and reapply new sealant.
Apply a continuous bead of sealant of the specified thickness to the differential housing cover.
Use Clear Silicone Rubber D6AZ-19562-AA or equivalent meeting Ford specifications ESB-M4G92-A.
NOTE: If possible, allow one hour before filling the axle with lubricant to make sure the silicone sealant has cured.
Install the differential housing cover.
Install the 10 bolts.
NOTE: If it is necessary to refill a Traction-Lok® axle with new lubricant, add 118 ml (4 oz) of Additive Friction Modifier C8AZ-19B546-A or equivalent meeting Ford specification EST-M2C118-A before filling the axle with the new lubricant.
NOTE: In-vehicle repair refill capacities are determined by filling the rear axle with the specified lubricant to 6.4-14.3-mm (1/4-9/16-in) below the bottom of the fill hole.
Fill the rear axle to the level shown, approximately 1.66-1.77-liters (3.5-3.75-pints) of lubricant, and install the filler plug.
Use SAE 75W-140 High Performance Rear Axle Lubricant F1TZ-19580-B or equivalent meeting Ford specification WSL-M2C192-A.
Lower the vehicle.
