Got killed again tonight :(
Why do people have to be so difficult? If you want a little tech help answer the questions because they are being asked for a reason to help you and for them to understand you clearly. There is no need to hassle people are here to help out man.
I doubt he's getting anything done. $50 says his dad comes across some problem and they call the swap off. Then he'll be wanting to know why he didn't beat that '76 bug with his cold air intake and premium gas going in reverse.
³à³ said:
Anyone ever hear of the 4.2L V8 from 81 Stang? Thats what Im getting for like $500 running.
Not trying to be rude!! :bs: but, asking this question on a forum for hmmmm cars is kind of Toolish don't you think?
³à³ said:
Whats wrong with the 81 Mustang V8? I just found out its 255cubes but about same power as the 5.0 from that year with more MPGs :D
Cubes???? Pubes???? Tubes??? Newbs???? Please use the correct terms and when someone corrects you and politely explains the correct terms. Go with that and use them. Please.
³à³ said:
And btw the 4.2 weighs just 35lbs more than your 2.3T
You might want to compare the 255 weight to the 302 while you're going there. I'm guessing the 302 could be lighter.......
BTW, even Ford stopped talking about the 255 real quick. From the ones I've seen, the milage was as bad (and worse) than the 302 and was gutless to boot but most guys fix that problem by putting in a 302!
If economy and speed are what you're after a turbo 4 is a better choice over either V8. Do your homework, I'm sure you can locate a donar car in your area (where-ever that is). If a SB V8 is what you want, stick to the proven engines 289, 302, 351. Other than that, if the rest of the car is worth $500, fill your boots.
.....don't know why that kid used that goofy playstation car and not the parts truck to race Vin in FF. :shrug:
HD
:bang: :bang: :bang:
Well you fools are all wrong. The car is up and running and sounding good. Unlike the pos 2.3 that got replaced that sounded like a fart in a can.
We have gone for a road test and though it isnt a race car it does pull evenly and will bark 2nd pretty easily. Id bet my left ball it will run in the 15s now. So for less than $800 total invested (without exhaust) I will have shaved over 7secs off the car.
The V8 sound alone was worth all the busted knuckles.
