Got my 347 dyno'd (but still got some issues)
Joe 5.0
1,184
Macomb, MI (metro detroit)
Thats what my car laid down today.
HOWEVER, we were not able to get it to pull past ~4700, as I have a pretty decent misfire. The cam is spec'd to have peak hp @ 6k, so it should be pretty easily into the 410-425 whp range once I get the misfire figured out.
The combo is as follows:
  • 347 CI (forged everything) ~ 10.5:1 compression
  • Jay Allen solid roller cam (~600 lift)
  • Canfield 195 heads (spec'd by Jay Allen)
  • Victor 5.0 intake (upper extrude honed, lower port matched to heads, inlet 90mm)
  • 90mm Accufab TB, 90mm MAF, 4" intake tubing)
  • 1 3/4 Accufab LT's w/ 3" collector, 3" offroad hpipe
  • 3" Hooker Aerochambers (loud) with dumps
As you can see I am leaving alot of power on the table, as tq is STILL climbing when it starts to cut out. I have to figure out if its the plug wires, cap/rotor, distributor, or ignition box (or something else :/ )
Its frustrating that its STILL not 100%, but its moving in the right direction. As soon as I get the misfire figured out it'll go back for a couple full pulls to 7k. :)
The torque peak of 388 at 4750rpm looks to be right on the money. The problem is the horrendous misfire from 4900-5700rpm and then again from 5800rpm upwards. The peak of 395 at 5750rpm gives a good indication of what your 347 is capable of. I think the peak will be more like 400 at 6000rpm when you've sorted out the misfire. Redline will effectively be at about 6500.
