  • 2.3L (N/A & Turbo) Tech
Got my codes
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date Sep 20, 2006
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Sep 20, 2006
  • Sep 20, 2006
Ok i went to schucks and read the codes this is what i came up with:
KOEO: Code 629 Torque converter clutch solenoid circuit faliure
Code 566 3-4 shift solenoid circuit faliare. Could these come up cause the car use to be an auto and now a T-5?
Memory codes were:
157 MAF below minimum voltage
223 Loss of dual plug inhibit control
224 Powertrain control module detected coil 1,2,3,4 primary circuit failure dual plug
332 EGR Flow insufficient
These are on my 92 4 cyl any help or ideas would be great! peace
john
stykthyn
5,232
2,652
223
gainesville
Sep 21, 2006
  • Sep 21, 2006
sounds like your ignition took a dump. how is it running?
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Sep 21, 2006
  • Sep 21, 2006
Eh, yeah, very much so. The "circuit failure" means that the solenoids either have a break somewhere or just aren't plugged in. I suspect you removed them for the swap...
Memory codes were:
157: The MAF probably lost either power or the ECU reference voltage at some point while the engine was running.
223: Search me
224: Sounds like the same thing as the transmission solenoids; open circuit at some point.
332: There is a sensor on the EGR valve to make sure it is opening and closing like it should. Yours is most likely stuck, but cleaning the valve is pretty easy. That's my immediate take on the codes. It's 11 at night and I'm going to sleep.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Sep 21, 2006
  • Sep 21, 2006
Um well it seems to run sorta fine? It always feels like it's not putting out full power. So what then replace the coil packs? Both of them? What about the MAF? Clean or replace it also? peace
john
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Sep 21, 2006
  • Sep 21, 2006
223: Search me
So the tranny codes is ok well i mean i dont have to worry about them cause of the t5? I didnt do the swap it was done when i bought it. peace
john
stykthyn
5,232
2,652
223
gainesville
Sep 21, 2006
  • Sep 21, 2006
well yeah, its a 4 banger. do a full tune up. reaplace all the plugs, wires, and fluids. clean all your sensors. pull the MAF and clean it. the EGR throws a lot of oil in there so it may be gummed and not giving a good reading.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Sep 21, 2006
  • Sep 21, 2006
I've already done all the above except clean the MAF. peace
john
65ShelbyClone
4,675
38
119
Sep 21, 2006
  • Sep 21, 2006
Be extremely careful if you do try to clean the MAF wires. They shouldn't even be dirty enough to matter if there has been an air filter on the car for the last 13 years. BTW, the EGR doesn't do anything with oil. A funky PCV valve would responsible for oil in the intake, but residue sure as heck shouldn't be reaching the MAF. Something that could oil the MAF is a cotton gauze air filter that has filter oil....like a K&N.
On the shift solenoids, you could find some resistors with the same impedance(resistance) as the original solenoids themselves and make jumpers out of them. That would fool the ECU without burning anything up. That or get a 5-speed ECU.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Sep 21, 2006
  • Sep 21, 2006
So with having the 5 spd in there instead of the auto could cause it to throw cods and possible not run right? peace
john
stykthyn
5,232
2,652
223
gainesville
Sep 21, 2006
#10
  • Sep 21, 2006
  • #10
pcv!!!thats what I meant to say. sorry had egr on the brain. stupid anachronysms
65ShelbyClone
4,675
38
119
Sep 21, 2006
#11
  • Sep 21, 2006
  • #11
I don't know. The solenoid "simulators" would at least keep the codes and CEL from coming on.
Do you mean abbreviations or acronyms?
stykthyn
5,232
2,652
223
gainesville
Sep 21, 2006
#12
  • Sep 21, 2006
  • #12
acronyms, I was trying my G. Bush impression.
Shawneebear93
20+ Year Stangneter
May 4, 2004
518
17
49
Salisbury Twp, Allentown, PA
Sep 21, 2006
#13
  • Sep 21, 2006
  • #13
I'm so lost after the last 4 posts or so?
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
D
Engine Shuts Off - With and Without CEL
  • DualXhst289
  • May 7, 2020
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech May 12, 2020
DualXhst289
D
Engine Need help with fox body code results.
  • sav22rem22
  • Feb 17, 2020
Fox 5.0 Mustang Tech Feb 17, 2020
sav22rem22
Engine 93 Mustang GT, Code 41/91, KOER Cylinder ID shows 6 and not 8
  • 79MercCapri93
  • Apr 28, 2019
  • 2 3 4
15K
Fox 5.0 Mustang Tech Jun 17, 2020
79MercCapri93
M
Electrical 92 GT 306 Vortech - Did I fry my ECU???
  • Mrg2783
  • Apr 15, 2018
4K
Fox 5.0 Mustang Tech Apr 16, 2018
Mrg2783
M
