- Jan 20, 2002
- 491
- 0
- 0
Alright This is A solid Flat Tappet cam. Valve lash is .16 and .18
Intake. exhaust.
Gross valve lift, .5280" .5440"
Duration@ .020, 264* 272*
Duration@ .050, 234* 242*
Lobe Separation: 109*
Intake Centerline: 105*
Spec's at 105* Degree Intake Centerline:
Valve Timing at Open Close
.050" Tappet Lift: Intake: 12*BTDC 42*ABDC
Exhaust: 54*BBDC 8* ATDC
Alright this is for my Built 331 With AFR 185's, Vic JR intake, 750 Demon, 10.4 compression, Bassani LT's, Full MSD ign., All the bolt on's, Full drag Suspension, Tremec 3550, Alu Drive shaft ya know all those little thing's, 4.30 gear, 26X10 ET drag's..
So Do you guy's think a 10.99 or better Is to much to ask? I want to spin this thing 7000RPM. Thanx
Intake. exhaust.
