got my ranny installed. need help!
  • Thread starter Thread starter AMERICANIRON
  • Start date Start date Jun 30, 2004
A
AMERICANIRON
  • Jun 30, 2004
i replaced my t5 with another because the one i had when i bought it the 2nd gear was grinding. any way i got the new (or used) one in and the clutch catches waayyy to high. it doesnt catch until i take my foot completely off of it. even then its still not fully engaged because i have a major loss of power. if i stab the throttle, say in 3rd gear around 3 grand from a cruise, it will break loose and rev to about 5 or 6 grand while still in gear. how do i adjust a clutch? thanks in advance.
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jun 30, 2004
  • Jun 30, 2004
do yoou still have the factory quadrant on there? if so, take it off, its a piece of junk. get a upr triple hook quadrant and firewall adjuster with a new ford oem cable from MM or somewhere that has them pretty cheap.
A
AMERICANIRON
  • Jun 30, 2004
geez! how much they cost? where to get em'? and what is involved in the installation? thiers no way to adjust the stock stuff for the time being? thanks again.
A
AMERICANIRON
  • Jun 30, 2004
why would it be out of adustment? i didnt change clutch's. same kinda tranny cept' out of a 90 ( i have a 89).
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jun 30, 2004
  • Jun 30, 2004
the stock piece is a kind of ratcheting thingy. it sucks. the upr quadrant was like 34 bucks and the firewall adjuster was the same price i think. both of them are really good pieces though. the cable is around 60 bucks i think. i dont know how to adjust the stock quadrant to loosen the cable, i know how to tighten it...but that doesnt help
A
AMERICANIRON
  • Jun 30, 2004
well im new to fox mustangs. this is my first and i got it about 2 months ago. where do i get the upr? how to install? it looks like i could adjust it on the firewall but like i say im new to foxes.
V
v8only
2,378
22
49
Jun 30, 2004
  • Jun 30, 2004
he's right about the firewall adjuster and quadrant
read this
http://50stangs.com/techarticles/clutchcableadjustment.html
you likely didn't reset your clutch adjustment when the new trans was in, and the cable is set too tightly on the oem quadrant.
for now, pull up on the clutch pedal hard with your foot, you'll hear a click, then press down. This activates the oem adjuster. If that doesn't work, head to
uprproducts.com, or maximummotorsports.com for a quadrant and firewall adjuster.
MSM0075
741
Central Jersey
Jun 30, 2004
  • Jun 30, 2004
I'd go with a MM set.
A
AMERICANIRON
  • Jun 30, 2004
v8only you got mail. nice website.
RYC CUKR
1,437
Orlando
Jun 30, 2004
#10
  • Jun 30, 2004
  • #10
yeah I would say a new quadrant, adjuster and a new cable. The cable in my 91 stretched pretty bad and eventually I destroyed the synchros in 2nd and 3rd.
D
dude5l
201
Grande Prairie, Alberta , Canada
Jun 30, 2004
#11
  • Jun 30, 2004
  • #11
In the meantime, try pulling up on your clutch pedal until you hear a "click" That should bring it back to adjustment.
P
Pop-Pops-Pony
254
Sharpsburg, MD.
Jun 30, 2004
#12
  • Jun 30, 2004
  • #12
2 ideas...
with the motor off push in the clutch and slide your foot off it...Let it bang back up...Thats one way to get it to adjust...
The other way you have to stand on your head and get up under the dash by the acceclerator pedal...find the 'white" plastic ratchet the cable hooks to and feel behind it for the "pawl" that engages the teeth on the plastic...Push it away from the teeth and you can move the part with the teeth so the pawl engages in a different spot...Careful it might move on it's own, I forget if it's on a spring...
Forget which way does what you want so try both...
If the stock part isn't broke and you can get it to work, why pay for something that does the same thing????
V
v8only
2,378
22
49
Jun 30, 2004
#13
  • Jun 30, 2004
  • #13
Pop-Pops-Pony said:
2 ideas...
that's a fantastic way to snap a clutch cable, and possibly damage your transmission and clutch components.
I've actually heard of this, and tried it, it is spring loaded, and I couldn't get the damn thing to budge for the life of me.
the bottom line is that if you pull up on the clutch pedal, and then depress it, and your clutch isn't adjusted properly after that, your stock setup IS bad, and it's time to replace it with an aftermarket quadrant and firewall adjuster.
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jun 30, 2004
#14
  • Jun 30, 2004
  • #14
doesnt pulling up on the pedal tighten the cable? because i know thats what you are supposed to do when the cable would stretch or the clutch would wear down a little bit. hes havin a problem with it catching too high. hmm...
V
v8only
2,378
22
49
Jul 1, 2004
#15
  • Jul 1, 2004
  • #15
pulling up on the pedal disengages the two plastic quadrant pieces from each other. Pushing back down on it will reset it. For that reason, it could either tighten or loosen the adjustment based on what is needed.
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jul 1, 2004
#16
  • Jul 1, 2004
  • #16
oh ok, i just didnt know how the ratcheting mechanism works. guess i learn something new everyday. usually from you...haha
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Need a clutch, 1982 Capri RS 5.0 owner, am I allowed to participate?
  • scudzuki
  • Apr 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 7, 2025
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
