Got my Vortech today...
  • Thread starter Thread starter pb_paulie_b
  • Start date Start date Jan 14, 2006
pb_paulie_b
894
Chaptico, Maryland
Jan 14, 2006
  • Jan 14, 2006
Finaly got my YS today. I'ts gonna be some time before I bolt it on. Is there anything I need to check to make sure it's working properly?
joeyd0730
130
queens, ny
Jan 14, 2006
  • Jan 14, 2006
i would check the impeller, looks a little shady.
pb_paulie_b
894
Chaptico, Maryland
Jan 14, 2006
  • Jan 14, 2006
What am I looking for? Thanks
joeyd0730
130
queens, ny
Jan 14, 2006
  • Jan 14, 2006
just check for play in the shaft. also check the blades make sure they are smooth. i had a small little crack in one of my blades, and while under boost from it spinning so fat it would flex. make a long story short i was loosing about 2 lbs of boost. had it rebuilt and all was well.IMO vortech is one of the most reliable blowers.
pb_paulie_b
894
Chaptico, Maryland
Jan 14, 2006
  • Jan 14, 2006
Heres a close up of it.
pb_paulie_b
894
Chaptico, Maryland
Jan 14, 2006
  • Jan 14, 2006
There is a slight amount of play when I more the impeller back and forth.
pb_paulie_b
894
Chaptico, Maryland
Jan 14, 2006
  • Jan 14, 2006
The impeller looks pretty good to me, no cracks, chips, or rubbing.
D
Daggar
3,902
  • Jan 14, 2006
Suck start it and see how much boost you can generate.
joeyd0730
130
queens, ny
Jan 14, 2006
  • Jan 14, 2006
make sure the blades cannot rub on thehousing. some play is fine. if it decides to rub, you will hear it. the clos eup looks pretty good.
Rick 91GT
Mustang Master
95
99
PA
Jan 14, 2006
#10
  • Jan 14, 2006
  • #10
Looks pretty good from the pics, you can call Vortech and register the blower in your name based on the serial. They can also give you the history on the blower if it has been sent in fro repair, etc...
pb_paulie_b
894
Chaptico, Maryland
Jan 14, 2006
#11
  • Jan 14, 2006
  • #11
Daggar, I don't have the motor in the car at the moment.
Rick, I'll definitly do that Thanks peeps
S&B
I hate my CT. :(
1,634
695
204
Cheesehead
Jan 14, 2006
#12
  • Jan 14, 2006
  • #12
what pulleys will you be running?
I run the pully's from the renagade kit, and i see about 22-23lbs with my YSI, i know there is a slight diff, b/t the two, but i would figure they should be pretty close
pb_paulie_b
894
Chaptico, Maryland
Jan 14, 2006
#13
  • Jan 14, 2006
  • #13
I don't know what pulleys. The kit came without them. I do know that I want to start with 10psi and when I get used to that run 15. This is a street car. Anyone wanna help me figure out the tooth count? Also should I go with the 8 rib or the cog set up? either way I'm planning on some kinda crank support...PB
ALMOST STOCK
1,250
41
88
CA.
Jan 14, 2006
#14
  • Jan 14, 2006
  • #14
Unless my way of thinking is wrong here... what Dagger was saying by
He was refering to you placing your lips here to generate that boost.
I could be wrong! I don't think so though ; knowing Dagger
pb_paulie_b
894
Chaptico, Maryland
Jan 14, 2006
#15
  • Jan 14, 2006
  • #15
I had my girlfriend try it, not much boost was made. Look hot though...
S&B
I hate my CT. :(
1,634
695
204
Cheesehead
Jan 14, 2006
#16
  • Jan 14, 2006
  • #16
hahahah
well your not going to want to go cogged if its a street setup, everytime you miss a shift you'll be throwing belts, run the 8 rib setup and im sure rick will know the right pulley setup to get you to the 10psi.
bill302
2,131
alabama,gadsden
Jan 14, 2006
#17
  • Jan 14, 2006
  • #17
pm me i'll give you my address mail it to me and i'll check it for you,free of charge! lol.
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
How do we feel about first gen fuel caps?
  • Teen'93stang5.0
  • Apr 25, 2026
  • Mustang Sound & Shine All
Mustang Sound & Shine All May 3, 2026
General karthief
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
