Got my Vortech today...
just check for play in the shaft. also check the blades make sure they are smooth. i had a small little crack in one of my blades, and while under boost from it spinning so fat it would flex. make a long story short i was loosing about 2 lbs of boost. had it rebuilt and all was well.IMO vortech is one of the most reliable blowers.
Looks pretty good from the pics, you can call Vortech and register the blower in your name based on the serial. They can also give you the history on the blower if it has been sent in fro repair, etc...
what pulleys will you be running?
I run the pully's from the renagade kit, and i see about 22-23lbs with my YSI, i know there is a slight diff, b/t the two, but i would figure they should be pretty close
I don't know what pulleys. The kit came without them. I do know that I want to start with 10psi and when I get used to that run 15. This is a street car. Anyone wanna help me figure out the tooth count? Also should I go with the 8 rib or the cog set up? either way I'm planning on some kinda crank support...PB
hahahah
well your not going to want to go cogged if its a street setup, everytime you miss a shift you'll be throwing belts, run the 8 rib setup and im sure rick will know the right pulley setup to get you to the 10psi.
