Ok I got in the car today and noticed that the low oil light was on again. So I checked it and once again it was about a quart low. On my way to the parts store I noticed a faint smell of burnt oil like it was leaking on the header. This started a couple months ago and I wa thinking that maybe it was a leaking valve cover. So I got around to changing that and then once again after about 2200 miles again I am low on oil. The thing is I had to remove the baffle in my valve covers to clear the rocker arms. I noticed some oil getting into my intake pipe so I took the breather hose that runs from the valve cover off and closed it off. Well after I done this it seems that this is what caused my problems cause shortly after that is when all this seemed to have started. I am thinking that I building up too much crank pressure without that tube and just a pcv valve and that is what is causing the oil to go like it is. So what do y'all think about all this and do you think that it will go away if I add a breather that is designed for a import to just the nipple where the breather tube use to be or should I leave that capped off and just add a full on breather cap in place of the oil fill cap? Or is this even the cause of the problem? Any and all help is appreciated!
