Got TKO installed, new clutch, but squeaking noise - is it throw out bearing?
SO I just shelled out $3,600 to put a new TKO in my 98 cobra, I didn't cut any corners and I will put the invoice at the bottom of the post so you can see what I purchased. I had the transmission, clutch assembly, etc (again all listed below) shipped from a very reputable performance supply shop that the mustang shop said I should order the parts from.
Of course I crank up the car and it has a totally different feel, and obviously driving it home, I am listening for noises that weren't there before and I notice that if the clutch pedal was fully released there was a squeaking noise coming from the around the clutch area(obviously). However, if I push the pedal in about an inch the squeaking stops. It will also squeak when in gear sometimes too, again unless I press down about an inch on the pedal. So my gut was maybe this adjustable clutch quadrant cable that the shop guy recomended I add after he installed the tranny could be my problem....
Turns out my buddy who works at another performance shops said - "yeah I have heard of this happening, let me ask the guys at work" Well they all immediately said it was the throw out bearing - and it was either bad/old/needed to be replaced, or was improperly installed.
My question is how do I approach the mustang shop that did the work - is this a no brainer that they have to fix it? I mean you can see in the invoice(from the shop that sent the tranny setup) that there was a new throw out bearing included in the kit. Is there any wiggle room they could try and get out of fixing it? Mind you I have had the car for a couple days since picking it up. My shop buddy said it requires them dropping the tranny out again to fix it - so I know the shop guy is not going to want to flip that bill willingly (I assume) The only other thing I can add is I know they didn't remove my h pipe when they did the install, but other than that they said it went in smoothly and later installed the quadrant cable. This mustang shop also had to rebuild my $7,000 engine rebuild twice in the past because the timing chain broke 200 miles after the rebuild(another horror story) So I know this guy is not going to be happy when I drop him another call with a new problem...
PLEASE HELP! I need advice on how to approach the shop!
Invoice from ProMotion Performance Products:
NEW TKO 500 FORD Transmission w/26 spline Input &
Lakewood Bellhousing 4.6L - 5.4L Ford
Drive Shaft Spacer Kit
Tremec 500/600 Shifter Stop Kit / INSTALLED
10.5" x 1-1/8 / 26 spl Kustom Dual Performance Disc
10.5" Blue Printed HI REV P/P (yellow)
FORD Throw Out Bearing $19.00
Labor to RESHIM & CHECK SHIFT LUGS / @ N/C
