Granada Swap Question
  • Thread starter Thread starter Grant65
  • Start date Start date Oct 29, 2004
G
Grant65
34
Orlando, FL
Oct 29, 2004
  • Oct 29, 2004
I'm planning on doing the standard Granada swap and managed to finally find a Granada in a salvage yard not too far from me. My question is: If the Granada has power brakes, can I still use the master cylinder and the booster on my non-power brake '65 coupe? From what I've read, it seems that the manual brake MC from the Granada is a direct swap. If it has power brakes (which I'd really like to have), can I use it, and if so would I need an adjustable push rod, or is there a correct length already out there? (The one from the Granada? )
Thanks!
Grant
blascrw
191
Opelika, AL
Oct 29, 2004
  • Oct 29, 2004
My .02
Well my opinion is I would not use a junkyard M/C or Calipers...
You do, and it fails...was it worth saving 60 bucks?
Go buy a new not reman M/C you can find many examples on the net as to which ones work well...
Search the web and find the info...
Ron
G
Grant65
34
Orlando, FL
Oct 29, 2004
  • Oct 29, 2004
OK, I should probably clear up that I wasn't going to use the master cylinder directly. I was just going to use it as a core (whether it was power or manual). Same for the calipers. But if the Granada has power brakes, and that's not going to work at all for me, then I won't bother pulling it while I'm there...
Grant
R
Ronstang
1,294
Houston Texas
Oct 29, 2004
  • Oct 29, 2004
The core value for both the Granada MC and calipers are so low that if you buy them in a salvege yard simply to have cores you will more than likely loose money. Just go get rebuilt calipers and MC (you are right, the manual MC is a direct swap) and pay the few dollars extra for not having a core. Last time I bought Granada calipers the core charge was like $3 each.
G
Grant65
34
Orlando, FL
Oct 29, 2004
  • Oct 29, 2004
OK, thanks! I didn't realize the core was that little.
As far as the power MC, is that a direct swap also, assuming I use the correct push rod? Or should I just get a power brake conversion from someone like MustangDepot?
Sorry for all the questions in a row, but I'm heading down to the junk yard right after work and just want to be prepared...
Grant
monk302
742
New Jersey
Oct 29, 2004
  • Oct 29, 2004
The only thing that I think that you really need to grab from the car are the spindles, the hardware that secures the rotor and caliper, the splashshield, and the proportioning valve. In my case I didn't have access to a proportioning valve so I bought one from Wilwood. As for power brakes, I don't think you will need them. I have the stock 15/16ths bore MC from the Granada without power and it is fine. The power brake are just and added expense that isn't really necessary IMO. I bought slotted roters, $99 per pair on EBAY from the Mustang Depot. Calipers and brake lines I bought from a local store.
Good luck.
Hack
1,945
Minneapolis
Oct 29, 2004
  • Oct 29, 2004
Backing up Monk. I agree with him. I have a non-power MC Granada setup in my '70 and it works fine. I think the reman MC cost me $18. Pretty cheap stuff. The bearings are about $2 each also.
For the brake lines I bought preflared lines from the local autoparts store and bent them myself. I was worried, but it was much easier than I expected. You will have to move the location of the fittings that attach to the flexible lines at the front wheels. The flex lines aren't long enough to attach at the stock locations.
Good luck.
G
Grant65
34
Orlando, FL
Oct 29, 2004
  • Oct 29, 2004
Sounds like I might just stick with manual brakes then (for now, at least). Thanks for all the help!
Grant
65mistress
405
Generica USA
Oct 29, 2004
  • Oct 29, 2004
If you are grabbing parts off of the Granada, get the outer tie rod adjustment sleeves too. That way the outer Granada tie rods will mate up to the inner mustang tie rods a little easier.
W
New here, 1967 getting an efi 348 stroker.
  • Weeman348
  • Mar 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
Weeman348
W
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
U
Knowledge Sought
  • USMCE3ROFP
  • Dec 6, 2025
  • Other Auto Tech
Other Auto Tech Dec 6, 2025
USMCE3ROFP
U
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
