  • SN95 4.6L Mustang Tech
Grenaded Diff. need advice.
  • Thread starter Thread starter donsbad68
  • Start date Start date Mar 27, 2006
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Mar 27, 2006
  • Mar 27, 2006
Well we grenaded the trac-lok in the bullitt on saturday (upper and lower spider gears and side spider gears, one broke in half other stripped all the teeth off of. Side gears were in turn chewed up.) The axles and the ring and pinion are still good. I was wondering what you guy would recommend for replacement diff. Also do you think we should get some new axles or the old ones will be ok? It runs around 8.0-8.1 in the eigth mile.
Thanks:SNSign:
imblown-ru
247
Roanoke VA
Mar 27, 2006
  • Mar 27, 2006
31 splines from moser with race studs and a 31 spline trac loc should do you right
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Mar 27, 2006
  • Mar 27, 2006
Do they come with the ABS ring already installed? If so please give me the part numbers!
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Mar 27, 2006
  • Mar 27, 2006
Also we would like to be able to race this weekend so if we can get a good setup with 28-spline it would save alot of time as far as seals and bearings. Thanks guys keep the opinions coming!
imblown-ru
247
Roanoke VA
Mar 27, 2006
  • Mar 27, 2006
A883153
APPLICATION: Fits 1999-04 Mustang - 31 spline, 5 lug with ABS adapter 8.8" Ford rear, 31 spline, 30 11/16" long Diag.
250/127.50
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Mar 27, 2006
  • Mar 27, 2006
If you are running on sticky tires I would upgrade to 31 spline.
helty
some Ukrainian's enjoying a handjob via my credit
Mar 30, 2005
1,461
Baltimore, MD
Mar 27, 2006
  • Mar 27, 2006
31 Spline FTW! Really, just do it now while you're in there. Maybe an FRPP 31 Spline Trac-Lock, they're rebuildable and pretty tough from what Ive read while researching the same question. Also, FRPP axles seem to be pretty strong too, made by Superior out of 1550 Steel as opposed to 1541 from other axles. Still not sure if I want Moser, FRPP or Superior, but Im just letting you know what Ive found while researching rear-end components.
http://www.buyfordracing.com/shop/product_info.php?products_id=545
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Mar 27, 2006
  • Mar 27, 2006
We run M/T Et Radials . ImBlown-ru, do those axles have the ring or dou have to remove your old one and re-use it?
imblown-ru
247
Roanoke VA
Mar 27, 2006
  • Mar 27, 2006
couldnt tell you. looks like it has the provisions for it and you reuse yours
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Mar 27, 2006
#10
  • Mar 27, 2006
  • #10
Currently we dont have a press available at our disposal and living in BFE makes the nearest machine shop about 45 min away. What do you guys think the limit is for the stock axles? Also does anyone like the PowerTrax diffs?
DropTopPony
Noob Slayer
2,570
south jersey
Mar 27, 2006
#11
  • Mar 27, 2006
  • #11
I really would upgrade to 31 spl axles while you have it apart. Only a matter of time until you break one then your 28 diff you just bought wouldn't work with the 31's...so you might as well do it right the first time.
Moser 31/Auburn Pro here with no issues.
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Mar 27, 2006
#12
  • Mar 27, 2006
  • #12
Who sells an axle kit that comes with the bearings, seals, and lugs all together. We really want to be able to race this weekend. 28 spline or 31 doesnt matter long as we get there.
helty
Mar 30, 2005
1,461
Baltimore, MD
Mar 27, 2006
#13
  • Mar 27, 2006
  • #13
http://store.summitracing.com/defau...eywordSearch&DDS=1&N=115&target=egnsearch.asp
If Im not mistaken they come with a 5yr warranty eek: I know, I said the same thing. A warranty on aftermarket axles? ) The only thing is I was told it took the person 5 months to get new ones. (his broke after 3.5 yrs and a butt-load of launches from high rpms on DRs and then Slicks) This is bc you have to send them back to Summit and then they do whatever they do through Superior to get new ones. Of course you would need new axles (should they ever break, not saying these will do that. ANY axle can break) so you buy new axles, and when the replacements come you can sell them. Just a thought.
EDIT: well that link wont take you right to what Im talking about, but you can navigate your way there. Just click FORD, then 8.8", then Mustang, then whatever year your car is. Or in your case its Part Number SAG-EV84 for an 02.
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Mar 27, 2006
#14
  • Mar 27, 2006
  • #14
it for an 01 Bullitt
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Mar 27, 2006
#15
  • Mar 27, 2006
  • #15
but i'm smelling what your stepping in
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
Betty white budget build
  • Stevenmverrill
  • Jun 16, 2023
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 15, 2023
2Blue2
A
any recommendations on differential shops Maricopa county to trust
  • aztecgwynn
  • Oct 22, 2018
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 22, 2018
90sickfox
How To Align Rear Lsd Side Gears Without Disassembly
  • Alpine615
  • May 4, 2017
2K
1965 - 1973 Classic Mustangs -General/Talk- May 4, 2017
horse sence
