grinding starter?
  • Thread starter Thread starter spade33
  • Start date Start date Jul 21, 2007
spade33
198
Tempe, Arizona
Jul 21, 2007
  • Jul 21, 2007
just a nother quick question...i hope...haha so anyways my car we just finished fixing the ignition switch wiring because it was cut of and the car would not start wtih the key, but anways after fixing that it started right up on the first try...YAY ok so then it was running kinda rough so i messed with the timing real quick and every time i try to start it now it makes a grinding kinda noise like the starter isnt retracting and keeping the motor from starting fully...any ideas why its a 66 289 manual transmission
enferno
418
  • Jul 21, 2007
pull the starter and check the splines and see if anything looks wrong.
could just be a coincidence that your starter failed the same time you decided to fix the ign. switch.
F
FLStang
58
Central FL
Jul 21, 2007
  • Jul 21, 2007
I just had something similar happen with my '70 Nova, the starter worked ok but it was noisy after it had been out and reinstalled. Sounded like the starter gear wouldn't disengage after teh engine got started, too. Turned out that the starter was not properly aligned with the flywheel. Reason: I missed one of the 3 bolts that hold it in place.... (shame on me)
Jan
scrutmonkey
243
San Jose, CA
Jul 22, 2007
  • Jul 22, 2007
had a rebuilt starter for a year, grinding noises. Thought maybe the battery wasn't pulling enough "umph" to start. I think my noid on the starter wasn't fully engaging the gear. changed the starter, no problems.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
uh oh that sounds like $$$$$
  • *HOOFHEARTED*
  • Jan 17, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jan 18, 2025
*HOOFHEARTED*
