  • SN95 4.6L Mustang Tech
grinding T3650
  • Thread starter Thread starter Ryan02Stang
  • Start date Start date Feb 22, 2004
Ryan02Stang
1,181
Arlington Heights, Illinois
Feb 22, 2004
  • Feb 22, 2004
When I shift into 3rd, unless I baby it in it grinds. If first started out when I would shift hard...like i said, now its a lot. What could be wrong? Is it my synchro? If its bad hopefully I can put the stock shifter back on and take it in for warranty. Thanks for any help!
krly79
464
VA Beach & So Illinois
Feb 22, 2004
  • Feb 22, 2004
Obviously there is something wrong so I would put the stock shifter back on and take it in. If they ask you about taking off the shifter, just tell them you thought something was wrong and took it off to see if you could see what was broke.
stangman
2,690
10
69
in a 3 bed, 2 bath
Feb 22, 2004
  • Feb 22, 2004
welcome to the club it sounds like the syncro though. the typical t-3650 problem is with the 2nd gear grind. so take it in & see what they'll do, hopefully it's not gone for a month like mine
Ryan02Stang
1,181
Feb 22, 2004
  • Feb 22, 2004
If mines gone for a month i will go NUTS!
Cobra5337
160
Edwardsville, Il
Feb 22, 2004
  • Feb 22, 2004
off topic, but I installed my 3650 and its louder than the stock shifter by a lot. I heard it would be sorta loud but not like this. Is there something wrong?
Ryan02Stang
1,181
Feb 22, 2004
  • Feb 22, 2004
Its a lot louder at first just because you are not used to it. Give it a week and you wont even notice...or get some loud exhaust!
F
fakefvc
458
Roswell, New Mexico
Feb 23, 2004
  • Feb 23, 2004
Maybe I should count my blessings, but my 3650 shifts perfect. I power shift and everything, no grinding what so ever. Maybe since I've had my Tri-ax on since day one has done something.
S.D.-Stangman
580
San Diego, Ca
Feb 24, 2004
  • Feb 24, 2004
I had this happen to mine as well. It started grinding like a Mo Fo one night as I was leaving the track...oops... Wouldnt grind if i babied it, but even in "normal" shifts it would.
Took it in to Ford with the Tri-Ax in place and they overhauled the tranny without a word to me about mods. It was the 3rd gear synchro by the way. Guess I got lucky!
Beau
3,050
San Diego
Feb 24, 2004
  • Feb 24, 2004
i'm curious, is there a synchro for reverse too? cause i have been having the grind in reverse really badly and i might have to take my tri ax off and put the stocker back on to take it in
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Jun 14, 2026
Mindseye007
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
