Ground getting hot?????
  • Thread starter Thread starter Stang951
  • Start date Start date Jul 25, 2004
Stang951
1,129
New Orleans
Jul 25, 2004
  • Jul 25, 2004
Should my ground terminal and cable get warm-hot when the car is running? If not what the hell would cause that?
F
forrealb50
163
VA
Jul 25, 2004
  • Jul 25, 2004
mine got so hot once the thing started smoking. it was a short in the battery, i replaced the battery and it never did it again. have the battery tested, or replace the ground cable. i think you can get a factory replacement at ford for like 13-15 bucks.
HISSIN50
34
129
Jul 26, 2004
  • Jul 26, 2004
i think if the cable itself is bad (i.e. corroded on the inside, has high resistance, etc) it will get hot too. that whole thing with juice flowing from ground to positive comes back to bite you.
shorty1993
212
Gadsden, AL
Jul 26, 2004
  • Jul 26, 2004
i agree
Stang951
1,129
New Orleans
Jul 26, 2004
  • Jul 26, 2004
I might try adding another ground wire to the frame as well as the chassis. The battery is in the trunk and right now it is grounded to a spot in the trunk. I doubt the cables are bad though since they are only about a year old.
Since it is in the trunk anyone think it could be a bad ground?
K
Kiknads
44
  • Jul 26, 2004
sounds like you need to add a second or larger cable, the extra distance/resistance from the car sounds like its adding a larger load to your battery that cant be handled properly by the current size
Stang951
1,129
New Orleans
Jul 26, 2004
  • Jul 26, 2004
I am using 1awg cable for about three feet to a panel inside of the trunk. I have another cable that I never made up to run to the frame....I guess I have to add that now.
What's funny is that I never noticed this before (then again I never go grabbing the ground cable either).
diddylx50
157
  • Jul 26, 2004
Im having the same problem right now with the relocated battery/hot ground wire....let me know if you fix that problem
Stang951
1,129
New Orleans
Jul 27, 2004
  • Jul 27, 2004
How do you have your grounds set-up?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 27, 2004
#10
  • Jul 27, 2004
  • #10
Best ground plan:
One 4 gauge ground strap from battery to chassis in trunk.
One 1 gauge ground from battery to engine block .
One 4 gauge ground strap from same place on engine block as previously mentioned to chassis near where the battery was originally.
Make sure the computer ground is connected to the chassis at the same ground point as the 4 gauge ground point previously mentioned. The computer ground has a round black cylindrical quick disconnect on it. It is a critical ground for EFI engines
Stang951
1,129
New Orleans
Jul 27, 2004
#11
  • Jul 27, 2004
  • #11
I thought you were supposed to keep grounds as short as possible? That is why I was going to run two seperate grounds in the front and rear. I have subframes in so the frame is tied together.
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
R
Help finding where this ground goes on the L head
  • RubberDuckUsb
  • Sep 11, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Sep 11, 2026
RubberDuckUsb
R
9
91 LX 5.0 getting hot when a/c is running
  • 91lx14gt5.0s
  • Jun 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 4, 2026
manicmechanic007
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
