GT 40 Head conversion
  • Thread starter Thread starter 65 fastback
  • Start date Start date Jul 22, 2008
65 fastback
1,347
Northern VA
Jul 22, 2008
  • Jul 22, 2008
I picked up some GT-40 heads (not 40p heads) off of Craigs List and just want to make sure that I don't slip up any where. I'm going to pull my 351 heads and install the new heads.
I, also, picked up some Crane 1.7 Roller Rockers, pedestal mount.
I got a gasket set for a '68 302 from Summit.
Anything that I should be aware of or watch out for?
Thanks,
Tim
9
96 DOHC Cobra
542
Cerritos, CA
Jul 22, 2008
  • Jul 22, 2008
It's definitely not a straight-forward swap. Unless those GT40 heads came off a 351W Lightning motor, you're going to have to drill out the head bolt holes to 1/2" diameter if you want to use them on a 351W. Installing them on a 302 wwill drop your compression a bit. Also, I think there's a mismatch on some water passages. You're supposed to drill the head or the block. I forget which.
D
D.Hearne
11,730
south louisiana
Jul 23, 2008
  • Jul 23, 2008
If you're going from the early Windsor heads to GT40's, there's hardly a difference there to justify the effort. Same valve/port sizes for both. The GT40 chambers are about 4 ccs bigger.
65 fastback
1,347
Northern VA
Jul 24, 2008
  • Jul 24, 2008
Posted via Mobile Device
65 fastback
1,347
Northern VA
Jul 24, 2008
  • Jul 24, 2008
The 351 heads I'm removing, arnt' the early heads, so hopefully I am gaining something with the GT-40 heads and 1.7 full roller rockers.
I'm installing them on a '68 302 block - do I still need to drill out any water passages? Can anyone point me to a link that can explain exactly what I will need to do?
Thanks for any help,
Tim
Fast63
717
  • Jul 25, 2008
You're installing on a 302, so there is no need to drill out the head bolt holes.
65 fastback
1,347
Northern VA
Jul 25, 2008
  • Jul 25, 2008
What about the water passages? Do I need to do anything to align the water passages? I thought this was a direct swap onto an early model 289/302.
Thanks,
Tim
D
D.Hearne
11,730
south louisiana
Jul 25, 2008
  • Jul 25, 2008
What 351 heads do you have now ?
shelbe67
309
Jul 25, 2008
  • Jul 25, 2008
on the older 289's i believe a hole needed to be drilled out as they didnt have it but when the switched over to the 302's they had them so i believe you should be ok
65 fastback
1,347
Northern VA
Jul 27, 2008
#10
  • Jul 27, 2008
  • #10
Thanks Shelbe67.
D.Hearne - I'm not sure what year they are. Where should I look to ID them?
Thanks,
Tim
D
D.Hearne
11,730
south louisiana
Jul 28, 2008
#11
  • Jul 28, 2008
  • #11
65 fastback said:
Thanks Shelbe67.
Thanks,
Tim
Look at the date code in the rocker valley. That'll tell you the exact date. Another way to generalize it is the number of intake bolt holes and the shape of the coolant ports on the intake side. Up untill about 1975, the coolant ports on the intake side are "L" shaped, with an extra intake bolt in the port.
65 fastback
1,347
Northern VA
Jan 19, 2009
#12
  • Jan 19, 2009
  • #12
Back from the dead.
The heads that I took off are 351W:
D80E AB
The markings inside the rocker valley are:
3 WC/P 77 3A20
They were rebuilt about 20K miles ago
with hardened valve seats and a 3 angle valve job
They also have Comp Cams Valve Springs - 942
Are these heads worth anything?
Tim
D
D.Hearne
11,730
south louisiana
Jan 19, 2009
#13
  • Jan 19, 2009
  • #13
65 fastback said:
Back from the dead.
D80E AB
3 WC/P 77 3A20
Tim
Aside from the valve springs? They're know to make dandy boat anchors. The chambers are huge at 70 cc's. The 3A20 says they're 1983 heads.
mr_woodster
1,314
Riverside, CA
Jan 19, 2009
#14
  • Jan 19, 2009
  • #14
Im pretty sure they are close to "bolt on" as you can get. Easiest way to check is to set the new headgasket on the GT40 head and see if it all lines up. If so, pretty simple. After that, its proper push rod lenghts and valve cover clearance.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jan 20, 2009
#15
  • Jan 20, 2009
  • #15
Wouldn't the D80E code indicate 1978 or is that the first year that part was made and the AB is the revision on that part ?
P
phutch11
328
Jan 20, 2009
#16
  • Jan 20, 2009
  • #16
You really need to check PV clearance especially if you know that the GTs have been shaved. Ask me how I know.
Additionally, despite what everyone says you may have header issues with the spark plug...again, ask me how I know.
I don't think you'll be terribly impressed with the GTs - I'm not. Unless the heads are ready to go with no work needed, I'd sell both sets and go get some Edel's or patroits and make some real power.
Good luck
Decurion
353
Livonia, MI
Jan 20, 2009
#17
  • Jan 20, 2009
  • #17
The gt40 heads (non-P) have the same plug angle as the old heads. I have a set on my car, and no clearance issues. They flow about the same as the 69/70 W heads, but just simple bowl blending in the intake and opening up the exhaust all the way through will make a world of difference. The combustion chambers are big, but the 93 Cobras were milled .030", so you could do at least that much to help with compression, depending what pistons you have. Also, these heads pretty much stop flowing by .500" lift, so keep that in mind in regards to your cam.
SadbutTrue
2,391
Thousand Oaks, California
Jan 20, 2009
#18
  • Jan 20, 2009
  • #18
Thanks,
Tim
edit: nm
I do recommend you consider milling the heads down to compensate for lost compression. I did .020" on mine, should yield about a half-point CR boost without compromising anything.
D
D.Hearne
11,730
south louisiana
Jan 20, 2009
#19
  • Jan 20, 2009
  • #19
The D8 only indicates the first model year it was produced. So a D8 part could have gone into production in late 77. Ford used the same Engineering prefix for years in some cases. Like the C8 302 rods, these were used untill the early 90's. Ditto for the E7TE heads, the last year would have been 1997 in the F & E series line.
Engine Felpro 9333 pt1 (with 8psi boost)
  • JD1964
  • Jan 14, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
Qtrhrse23
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
M
Pushrod length
  • mattcrp1
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 4, 2025
mattcrp1
M
For Sale Mexican 302 Block 60 Over , Comp Cams Roller Conversion and ARP Main Bolt/Head Studs
  • bluelx347
  • May 27, 2025
  • Engine and Power Adder
Engine and Power Adder May 27, 2025
bluelx347
SN95 New Heads
  • Blakeknight
  • May 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2025
