  • 1994 - 1995 Specific Tech
Gt Computer in a Cobra?
  • Thread starter Thread starter scottmrit
  • Start date Start date Oct 8, 2006
scottmrit
18
  • Oct 8, 2006
I have a 1994 cobra that has a tm40 in it. My cobra gets about 215 to a
tank and i am sure that the computer doesn't like the 24lb injectors. I
purchased a used j4j1 on ebay and my car idles and drives better with the tm
40,a lot better.
I think the j4j1 was DOA, so my options are get j4j1 rebuilt at ecudirect.com
(cost 200). Then i just have a stock j4j1, or do i purchase a chip that will
take care of the injectors. I am leaning towards a chip so i get some
performance out of it. If i get a chip do i need one for a j4j1 or do i need one
for a tm40?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Oct 8, 2006
  • Oct 8, 2006
The Cobra came from the factory with 24lb injectors, so that shouldn't be an issue. Did you try pulling codes at all? 215 miles to a tank doesn't sound too far off. The best I ever got out of my GT was somewhere around 230-240, and that was all highway miles.
scottmrit
18
  • Oct 8, 2006
This is a cobra engine being ran by a gt computer(tm40). The tm40 is setup to run 19lb injectors so it thinks i am running rich, so it is adjusting causing my mpg to be off.
BlownFiveLiter
18
108
Chicagoland
Oct 8, 2006
  • Oct 8, 2006
Ah, I get what you're saying now... If you have any performance mods in your future, you might want to look into getting something like a TwEECer for a couple hundred more than the new computer will run you. Then you can just load up the J4J1 file for the Cobra and tune as necessary from there.
blksn955.o
3,263
st.louis mo 314
Oct 8, 2006
  • Oct 8, 2006
WTF???
How is that thing even running? I tried to run my car on the stock gt eec. My combo is 95 cobra heads, exploder intake (gt40), 24lb inj, and a TFS cam and it at most will idle for 15seconds with a stock gt eec running things. I had basicly the same combo with 19's and the stock eec and it ran ok but I just dont see how your even getting it to idle
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Oct 8, 2006
  • Oct 8, 2006
You gotta be too fat as the pcm is pulsing inj's it thinks are 19's but in reality are 24's.
I can see how you could get by with that mismatched setup.
Only thing that makes me wonder how you did it was .........
the first few times you drove it ......
it took a while for the adaptive to peg full lean ......
I bet those first few drives were really nasty
Self tune, pro tune, or get the correct pcm
Grady
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
  • brandyn200
  • Jun 20, 2026
AeroCoupe
A
GT ABS Module in a 2001 Cobra
  • Aamer309
  • Oct 17, 2026
  • SVT Tech Forum
SVT Tech Forum Nov 3, 2026
Mustang5L5
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
