^Yes, but the stock injectors are the limit....and to compensate the fuel pump will have to increase pressure, and the fuel injectors will have to max their pulse width....and it still probably wouldnt keep up. So basically even if it did, you would be putting ALOT of strain on both the injectors and the pump.
With the wet kit, fuel is taken directly from the fuel rail....and the only real limit of the fuel pump, but with a large passage for the fuel to flow through, like supplied with wet kits, its easy for the pump to supply the flow of gas.
