Gt40 Combo With 1.72 Rockers
  • Thread starter Thread starter shakey1378
  • Start date Start date Aug 30, 2012
1 of 2 Next Last
shakey1378
25
  • Aug 30, 2012
F3ZE heads currently at machine shop getting checked out and freshened up. I have the crane/ford 1.72 rockers and plan to use what I have. Gt40 tubular intake, 70mm tb cobra maf, 19# injectors, headers, pro chamber, Mac dumps, wc t5, frpp ds, and 3.73 rear. Shops telling me e303 and friends are saying b303. I know these are old tech cams but can be had for cheap. Any other suggestions from you guys on cam selection. Car is my daily driver and soon to get the odd track day.
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Aug 30, 2012
  • Aug 30, 2012
i run a B in my car...
went 12.46@108 on its first kit...
went back last friday and trashed the diff....
shakey1378
25
  • Aug 30, 2012
Surprised no one else chiming in. I've got a couple telling me go custom, wouldn't mind hearing some results on that scenario or other off the shelf cams out there...
ViperPunk
195
idaho
Aug 31, 2012
  • Aug 31, 2012
TFS1 is another common one
shakey1378
25
  • Aug 31, 2012
How would tfs1 be with 1.72 though? Need to choose this weekend labor day sales I can steal a b or tfs1 new at the moment. A cam is one thing I'm pretty iffy about buying used...
ViperPunk
195
idaho
Sep 1, 2012
  • Sep 1, 2012
google it man! there are multiple threads on it ranging from mileage to performance aspects and Im not saying that to sound cross btw!
88LX5.Oh
1,442
205
94
Arkansas
Sep 1, 2012
  • Sep 1, 2012
E cam's lift is .498 IIRC. B cam's lift is .480. The lower lift on the B cam might help your valves from hugging your pistons
And I run a B cam. I like it
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
Sep 1, 2012
  • Sep 1, 2012
Anderson N21 cam. Designed for use with 1.7RR and GT40 heads. I run the N41, as of two weeks ago, with 1.7RR, but I have SRS pistons with large valve reliefs. The N41 and N21 are identical, except the N21 is designed for the 1.7 and the N41 for 1.6. They are not cheap though, $300 new. Just like everyone else said, you could go custom for a few dollars more.
Joe
ReefBlueHatch
682
96
39
Central KY
Sep 1, 2012
  • Sep 1, 2012
I have a TFS 1 with my P heads and stock rockers. I think the car's drivability is the same when it had the stock cam. If I remember correctly, TFS recommends 1.6 rockers with the stage one. I've only had the car to the strip once since the new combo; crappy track with no Trac-Loc and street tires ran 14.03 @ 102. I know she has more in her along with my terrible driving.
5point0stang88
205
15
29
Sep 2, 2012
#10
  • Sep 2, 2012
  • #10
Dude you don't a custom cam with a mild build, Gt40 set-up. Get an OTS can like tfs1. Better than both b or e. But between the letter cam, choose e if it's a DD. It had lower power band. You will dislike driving with a b cam on the street because it's all top end and no low end tq. Tfs1 has better street manners, and dual pattern can help you get more power.
Sent front my SGS3 Epic 4GLTE Touch
shakey1378
25
#11
  • Sep 2, 2012
  • #11
Maybe I'll go with an Anderson cam....really not wanting to have to deal with changing rockers out for 1.6 tfs could be close with my 1.72s my cars rarely under 2k Rpms on the street. Kind of looking for something to have a top end pull to 6k
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 2, 2012
#12
  • Sep 2, 2012
  • #12
Then you might want to rethink your approach with those GT40 top end parts. The small valve and port design make them a great head for a torquey street engine, but an untouched set of GT40 heads and GT40 intake are going to start running out of airflow shortly after 5,000RPM and be completely out of breath by about 5,500RPM. If you want them to pull any past that, I would at the very least work the exhaust side of the heads a little and do some porting to that lower intake.
All the cam in the world isn't going to help you if you're forcing the engine to breathe through a straw.
Maryland Stang
1,656
30
39
Greenville, NC
Sep 3, 2012
#13
  • Sep 3, 2012
  • #13
The B cam becomes .510 lift with 1.7 rockers.
shakey1378
25
#14
  • Sep 3, 2012
  • #14
E would be like .530 with 1.72 right. But b is more aggressive because of duration. I imagine it doesn't make too much sense to go crazy with a basic iron head combo but I definitely want the car to pull hard to redline for the odd track day. Could be a bit of time before I can afford a 347 build.
Maryland Stang
1,656
30
39
Greenville, NC
Sep 4, 2012
#15
  • Sep 4, 2012
  • #15
The B and X cams are very similar. I know the B cam gets beat up because it's an old grind, when matched with the right parts, it can still be a real performer and a whole lot of fun. And people do turn their heads and look when I pull into a parking lot or somewhere like a traffic light.
shakey1378
25
#16
  • Sep 26, 2012
  • #16
Bringing this back up, thinking about other than b303
Gearing forwards anderson n-21, steeda 18, crane 2031, or custom
Got my heads back with better springs 135 on the seat 320 open
shakey1378
25
#17
  • Sep 28, 2012
  • #17
After talking with Ed Curtis decision made he's grinding me a custom
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 28, 2012
#18
  • Sep 28, 2012
  • #18
That's a big expense for a GT40 top end. I personally don't think you're going to notice a difference from a decent off the shelf cam suggested above. Especially with the amount of used cams running around out there, but it's your money.
Got your heads back with "better springs". What springs are you running?
shakey1378
25
#19
  • Sep 28, 2012
  • #19
Comp cams 320 open 135 on the seat. Most ots new other than a b303 were within 30-40 dollars of a custom. I plan to upgrade to afr heads when money is better. Haven't found any used cams worth picking up and not knowing If that's a good option, one lobe messed up could grenade my motor no?
88LX5.Oh
1,442
205
94
Arkansas
Sep 28, 2012
#20
  • Sep 28, 2012
  • #20
Roller cams don't wear, to my knowledge.
1 of 2 Next Last
Progress Thread 88 Notched Fox
  • NotchedGarage
  • Jul 15, 2023
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2024
Flyboy60
F
New combo
  • 87slow.0
  • Oct 19, 2022
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2022
87slow.0
B303 Or E303 With This Combo. No Flames Please
  • Bill88Stang
  • Nov 18, 2014
Fox 5.0 Mustang Tech Nov 20, 2014
Mustang5L5
H
New Member, New Project, Long Time Mustang Fan
  • hobbydad
  • Dec 10, 2016
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 16, 2017
FoxMustangLvr
Picking Up New 89 Roller
  • Bill88Stang
  • Nov 22, 2015
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 22, 2015
Bill88Stang
