gt40 heads
  • Thread starter Thread starter 94GTCoupe
  • Start date Start date Mar 1, 2008
94GTCoupe
1,412
92
79
CA
Mar 1, 2008
  • Mar 1, 2008
had a little time today to look at the gt40 heads i got from a 96 explorer.the explorer had no smog crossover tube that connects at the rear of the heads.read somewhere that they would have to be machined to accept the tube.the hole on the head where the air should enter(or exit?) there is a hollow threaded plug.i could not get it out with any of the tools i have.so i put some jb weld on a bolt that fit the internal thread of the plug,tightened it down with my impact gun and let it dry.after awhile hit it with the gun and zipped the plug right out.the gt40 head is already machined and tapped for the bolts that attach the tube to the heads.i was worried that i would not pass CA smog,which is very tough.problem solved and i am relived.
9
95Monky
179
Chico, CA
Sep 25, 2011
  • Sep 25, 2011
sorry to drag up this old post but I have a question. I have a 96 explorer motor. the ports have freeze plugs in them currently. can I just pull out the freeze plug and bolt on the crossover tube?
94GTCoupe
1,412
92
79
CA
Sep 25, 2011
  • Sep 25, 2011
No.
That would open up the coolant passages in the heads.
The crossover on The back of the heads are for exhaust gas,not coolant.
99FiveOh
2,051
20
99
J-Ville, FL
Sep 26, 2011
  • Sep 26, 2011
I think he is just calling those plugs "freeze plugs" in error. I think just bolting on the crossover will pass visual but the fresh air won't make it to the heads so your emissions will be higher. One more reason I LOVE living in FL!
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Sep 26, 2011
  • Sep 26, 2011
I miss FL, and no emissions. I'm honestly looking at having to go through emissions twice before the engine is even broken in.
Kurt
9
95Monky
179
Chico, CA
Sep 26, 2011
  • Sep 26, 2011
I figured out they where coolant.. im guessing only cobra gt40 heads and the ports for the air injection??
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Sep 26, 2011
  • Sep 26, 2011
Do you still have the stock 4 cats on there? You could just cut the inserts off the thermactor pipe and bolt it onto the back of the head with it just blocked it off. I seriously doubt it will make any difference as to how well the car does in emissions.
Kurt
9
95Monky
179
Chico, CA
Sep 27, 2011
  • Sep 27, 2011
Ca emissions... Dont want to fail the sniffer portion.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Sep 27, 2011
  • Sep 27, 2011
I seriously doubt you will fail the sniffer. I ace the sniffer with no smog pump at all. The smog pump just gets the cats up to temp quicker, once they are there it makes very little difference. That is why most modern cars have an electric smog pump, it just shuts off once the car is hot.
Kurt
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Seemingly random 'will it fit' and 'how well does it work' kinds of questions...
  • JasonRP
  • Jul 3, 2021
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 14, 2021
2000xp8
Fox GT40P Heads Exhaust Setup
  • red5.0fox
  • Mar 19, 2021
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2021
rdharper02
Progress Thread My notchback project part two
  • MrFoxNutCase
  • Oct 29, 2019
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 5, 2020
MrFoxNutCase
Engine GT40 upper/lower EGR issues
  • Vulpes5.0
  • Jul 15, 2019
2K
Fox 5.0 Mustang Tech Jul 15, 2019
Mustang5L5
