Gt40 Intake Question
  • Thread starter Thread starter Dyoung471
  • Start date Start date Apr 15, 2015
D
Dyoung471
  • Apr 15, 2015
Hi, New 1990 Mustang LX owner here. I plan to keep my mods very basic as I live in California.
current mods:
GT40 Intake
K&N Filter
BBK Shorty headers
Off Road H pipe
2.5" Flowmaster Exhaust
Would the benefit of a MAF/TB be worth the cost with these basic bolt ons?
Also could I upgrade the MAF and TB while maintaining my stock #19 injectors?
I am still deciding long term what to do with the car, I want to keep my mods minimal for now because I may go Vortech later on and do not want to waste money if I decide to go that route.
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Apr 15, 2015
  • Apr 15, 2015
Unless you are planning on upgrading your heads I would not spend a lot of money or start throwing parts at it.
MAF- get one from a 94-95GT. It is 70MM vs, the stock fox body at 58MM. The transfer curves are very similar and will give you additional pick up. You'll need to either fabricate or purchase the adapter ring so it fits to your stock intake tube- They are like $15-20 on Ebay.
TB -you can uses the 65MM TB from an explorer. Just corect the likeage per the tech article on Stangnet. You don't need a 70MM.
Injectors- keep the stock 19's. No need to go larger until you add the Vortech.
If you can get 93 or better octane, then bump your timing up to 14 or so for some free low end pickup.
Reactions: jrichker
D
Dyoung471
  • Apr 15, 2015
Thanks for the advice! Ill go with those parts til I figure out which direction to go.
Reactions: A5literMan
Mustang5L5
Mod Dude
Feb 18, 2001
43,390
18,132
224
Massachusetts
Apr 17, 2015
  • Apr 17, 2015
for the MAF, i'd just get a used 94-95 GT MAF and adapter ring and call it a day.
I wouldn't bother with a throttle body at this point. You have stock heads so there's only so much air you can cram into them. I'd hold with the GT40 intake and larger MAF and focus on something else.
If you can get a good deal on an explorer 65mm TB and modify it, go for it/.
D
Dyoung471
  • Apr 19, 2015
I know its all in the driver but does my combo have high 13 second potential as it is?
Mustang5L5
Mod Dude
Feb 18, 2001
43,390
18,132
224
Massachusetts
Apr 20, 2015
  • Apr 20, 2015
Not enough info give.
5-spd I'm going to assume?
How many miles are on the engine? Brand new back in 1990, i'd say yes. But 25 years later, with XXX amount of miles. Hard to say. These cars were rated 225HP new, but I bet many aren't making that sort of power these days with almost 200K miles on the clock.
Basically it depends on overall condition, but the potential is there with a good driver. I'd prob estimate 14.1-14.5 personally
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Apr 20, 2015
  • Apr 20, 2015
Stock gears and non drag tire = mid to high 14's maybe even low 15's. Now if you have a good tire,lower gears(3.55-4.10),a solid running engine,and drive it well...maybe a high 13
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Apr 20, 2015
  • Apr 20, 2015
if you have good air, remove everthing from the trunk, run a short belt, ice down the intake, advance the timing to 14, bump up the pressure in the fron tires to about 45, lower the pressure in the stock rear tires to about 25, disconnect the front sway bar, and drive it like you stole it
Yes mid 13's if you hook
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
