  • 1994 - 1995 Specific Tech
gt40 intake
  • Thread starter Thread starter tstang21
  • Start date Start date Jan 7, 2009
T
tstang21
219
  • Jan 7, 2009
im preparing to buy a ported gt40(explorer) intake from a friend. his intake by far had a great torque band from the graph the last time he tuned it. i know i need gaskets and a bigger TB. what do i need to complete the swap? fuel pressure regulator, bigger injectors ? suggestions
94GTCoupe
1,412
92
79
CA
Jan 7, 2009
  • Jan 7, 2009
intake elbow,i think you can get away with just the FPR.
got my PP intake elbow here.
MUSTANG-UPR Products.com
T
tstang21
219
  • Jan 7, 2009
i forgot to mention about the elbow. what i read from another thread that if any manifold is going to be installed on our cars, the EEC would have issues with vaccum, A/F ratio problem,etc. i highly doubt it this but would like to give it a 2nd thought. acoarse it has to done right. would it be nesscary to get an adj FPR that you can tune? also would get away with just leaving 19lbs injectors on ? btw im still stock.
R
red dragon95
50
north las vegas
Jan 7, 2009
  • Jan 7, 2009
19lbers are safe to use.you dont need larger injectors untill you go forced injected or get heads and a cam.the added air from the ported explorer isnt enough to warrant a tune,and you can use the stock regulator the adjustable isnt needed its more of a want than a need.i have a bbk adjustable new you can have for say 50.i put it on and drove it for 5 miles and found the problem was a vac leak so i put the stocker on and havent done nothing with it.can send pics if ya like.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Jan 9, 2009
  • Jan 9, 2009
if you are just putting on the intake , you should be able to just use the adaptor and get the proper gaskets and put it on without doing anything else to the car and it should run fine
JJ95GTID
1,141
Phoenix, AZ
Jan 10, 2009
  • Jan 10, 2009
x2
Just the elbow is needed. Everything else just swaps over. I have the Explore intake. I used the the stock injectors, tb and MAF with the Explorer intake and aluminum heads with 1.7:1 rolller rocker arms with no problems.
T
tstang21
219
  • Jan 10, 2009
sounds good. im going to powder coat it first. since it's ported upper/lower, i bet ill get LOADS of tq then usual come dyno time soon . my boy went over the 300 mark with this
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
Engine Brackets for Gt40 heads with ac and ps?
  • Xavierg208
  • Nov 14, 2025
Fox 5.0 Mustang Tech Nov 16, 2025
limp
Gt40 e303 combo questions
  • 99mustanggt2018
  • Mar 30, 2025
1994 - 1995 Specific Tech Mar 30, 2025
KRUISR
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
