GT40 Irons - Is there a difference?
  • Thread starter Thread starter TheBocSez
  • Start date Start date Oct 8, 2005
TheBocSez
652
Converse, TX
Oct 8, 2005
  • Oct 8, 2005
I was wondering if there is a difference between the GT40 Iron head found on a Lightning as opposed to those found on a 93 Cobra?
The only I could think of would the the possible need for headbolt bushings on the one from the Lightning. Any other differences?
I have access to some that are close by from a Lightning or some I can buy and have shipped from a Cobra.
Just trying to see which will work with my car with the least amount of trouble. BTW, it have a 91 LX.
Thanks!
notchback
1,950
St Clair Shores MI
Oct 8, 2005
  • Oct 8, 2005
nope...same head
i've heard that early explorer heads are real 40's and not "p"'s but i have never spoken to anyone who actually knew...just heard it around
I
IntenseBlue
946
  • Oct 8, 2005
I think the lightnings had 2cc bigger combustion chambers. Not positive though. The Cobras and Lightnings weren't Ps. The 97-up 5.0 explorers had Ps.
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Oct 8, 2005
  • Oct 8, 2005
But not all '97 Explorers/Mountaineers had the P head. They switched from GT40 to GT40 P midway through '97, so some of them do, some of them do not. My '97 Mountaineer heads are regular GT40's because they're early '97's.
rd
3,316
63
109
Ocean Springs MS
Oct 8, 2005
  • Oct 8, 2005
I have a set of SVO GT40 irons and a set of Lightning GT40 irons. Both have the bigger head bolt holes. The Lightning set had the production valve spring rotators on the exhausts, which I changed out to Comp Cams springs, retainers and keepers. Ohterwise I dont think there is any significant difference. I have one set on a 68 block and one set on a 79 block. Work fine.
87MustangGT5.0
153
Maryland
Oct 8, 2005
  • Oct 8, 2005
Is there a big difference between the P and the non-p?
I
IntenseBlue
946
  • Oct 9, 2005
P's require different headers, but they make more power. Nothing huge, though.
SeventyMach1
Mar 30, 2005
1,940
North Carolina
Oct 9, 2005
  • Oct 9, 2005
Uh, no, P's DO NOT necessarily require different headers!!! I know many guys that run them with regular headers. You may have to modify 1 or 2 spark plug boots (to 90 degree boots) .... but regular headers will work just fine. And yes, the P's will make just a little more power.
TheBocSez
652
Converse, TX
Oct 9, 2005
  • Oct 9, 2005
Cool, thanks for the info guys. Since the Lightning heads are cheaper, closer, and more recently machined, Im going with those. Thanks again.
E
Serpentine ac bracket differences
  • EspaceF1Fan
  • Apr 1, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 1, 2026
OX1
O
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
M
1993 2.3 Auto to 5.0 Manual
  • malikaimiller08
  • Aug 28, 2024
3K
Fox 5.0 Mustang Tech Aug 31, 2024
95steedamustang
