gt40p swap
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
just did a gt40p swap and having hesitation problems under load. idles fine but exhaust kind of sounds like it might be missing a little bit. wondering if spark plug wires could be causing this problem..currently i have the spark plug wires zip tied together because of the way the headers are so close to the wires. i know you shouldnt have the wires together like that but i didnt want them burning on the headers.
Step 1.) Get a squirt bottle that you can fill with water and adjust for a fine mist. Park the car in a dark area and open the hood. Start the engine and spray the mist around the spark plug wires. Look for sparks, arcs and flash over. Separate the wires according to what you see.
Step 2.) No significant flash over or sparks visible in the above test:
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Alternate methods:
Or for a nicer scanner see Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
I think that I might have an idea why this is happening.. Tell me if this makes sense.. When I was doing the swap I accidentally got antifreeze down the driverside header. When I first started the car it smoked out the drivers side pipe as soon as it got hot enough to burn the antifreeze residue up at the header.. I didn't take the car out to drive until yesterday.. But I let it idle on Sunday night for about a half hour while I was filling and burping the radiator.. Seemed like it burnt off all the antifreeze.. But I think that the antifreeze that got down into the h pipe is still there because the exhaust didn't get as hot to burn it off yet. So I took it for a drive and the hesitation started around the same time as the smoke.. Could it be possible that the o2 sensor is reading the burning antifreeze and screwing with my air fuel mixture..
Could an intake leak cause this problem because the motor is getting unmetered air? I'm thinking it could be a possibility it is leaking where I drilled and tapped the hole for the iat sensor in the 5th cylinder.. Didn't get a chance to spray some throttle body cleaner around to see if there is a problem on the intake yet.
