GT40P vs. GT40X Turbo Swirl
98CobraClone
592
Ripley, Ohio
Does anybody know if the exhaust port location is the same between the two? My stock manifolds won't work with the "P" heads and I'm looking for another set of fairly cheap heads to go with, but just wanted to check the exhaust setup and to see if the spark plug relocation is in the same place.
Any help is greatly appreciated.
i dont know about your hardware situation, GT40X are WAY better....run those if you can. they flow much better, and theyre aluminum...better handling, less weight, about 50 lbs...find some flow charts, ive seen several, but im too lazy to look for them right now
