GT40X Heads (64cc) and F303. Piston clearance?
thefordkid1
21
Hey fellas,
I have gt40X heads (1.94 and 1.54) never milled.
Stock 1994 5.0 block and pistons. Never machined.
I want to purchase an F303 cam.
I know I must check piston to valve clearance.
If I install it and it doesn't clear I most likely will not be able get a refund of my $200.
Does it usually clear?
i've got the gt-40x heads with a b-cam and 1.72rrs.that should equal your f-cam and 1.6s.mine clears fine.let me know how it runs because after christmas i'm going to switch to 1.6s and a f-cam.
Close except the f-cam has a LSA of 114 vs. 112 for B.
Thanks for the reply. If I try it....I'll let you know rattrap.
Someone on here must have an F with GT40X heads.
Where are you?
