gt40x heads
310stanger
170
a buddy i work with who also has a 90 5.0 lx hatch like me had a simple 302 stock short block with an ecam and gt40x heads. well he recently bought a dss 331 with cnc twisted wedges and when he pulled apart his old engine he found yet another bent pushrod. upon further investigation after tearing the heads apart he found the exhaust valve guides on nearly every cyl on one head were completely worn. the valve would shake back and forth excessively. the heads only had approx 60k miles if that. has anyone else ran into that? that seemed really premature to me. god i hope my trickflows dont do that. i dont wanna have to constantly pull this engine apart all the time.
A friend of mine has X heads and had problems with the valve guides. He bent two valves and there was a lot of scoring on the valve. It looked like something was inside the guide causing the problem...and that was with only a few thousand miles. He ended up having the valve guides replaced and a complete valve job done and the problem went away.....after tearing them apart twice because of two bent valves at two different times.
This is why my buddy who owns a mustang only shop, takes all heads to the machine shop, new or used, they still go for a valve job and spring seat pressure job.
He tells everyone to factor in at least $250 into their budget. Years ago (at least 10), he got tired of bad factory valve jobs causing problems. Even the better heads like afrs and TW's aren't immune to these problems.
