I'm unable to turn up the boost because it goes lean if I do but here is the results with the gillis turned all the way down to 9psi.
Prior to this I had a bob's log, hybrid, ported head, and K&N. Still had the stock exhaust even. In 50º weather I ran 15.8@86mph @ 9psi.
Now I removed the exhaust, added one of my headers, a FMIC, 35lb injectors on the stock computer, and a blow thru vam. In 95º weather I ran a [email protected] @ 9psi
It's still untuned and 9psi isn't even beginning to put that hybrid, FMIC, etc. to use so I'm pretty happy with the results. Should be fun when I crank up the boost
[Edit] I fixed a small problem today and now it's running richer...looks like I should be able to get a few psi out of it safely now...new times to come.
Track is open again on the 25th...I'll be there.
Stinger
Stinger
