Guage Cluster
Djstorm100
109
I hate to keep making post like this, but I dont want to messed something up and have to re do it. Plus its the only way to learn right? Other than messing up alot.
Point is I'm going to be putting autometer guages as my cluster. Now I was looking at people that made plates and ect for them. At the bottome I have picture of the all the wires. My question is What would be the best way to wire the guages up. At first I was thinking runing 12 guage wire and splice all the black in to one wire. Then run around 12 guage wire and splice all the white wirtes in to it. Would this be safe? I've wired up guages before just not this many all at once. I'm worried about load and getting the wire too hot. These are mech guages and I play to run Elec ones
I hooked them all together in the back with spade connectors then ran 1 and it was fine. I would not twist and tape because you don't want to keep taking it apart for a loose wires. Spade connect them.
The 12 gauge wire will carry 20 amps. The gauge illumination will only draw 2-4 amps at most. You should use an 18 gauge wire for the power and ground for the illumination circuit.
Using the 12 gauge wire for a ground won't hurt anything, but the wire is larger and will not bend easily to fit around the turns and curves.
I would use a separate 18 gauge wire to provide ground for the other gauge circuits.
Wire size current table for automotive use, total run lenght of less than 20 feet.
18 gauge wire = 5-8 amps
16 gauge wire = 10-12 amps
14 gauge wire = 15-17 amps
12 gauge wire = 20-25 amps
10 gauge wire = 30-40 amps
8 gauge wire = 50-60 amps.
so run 18-16 awg wire off each wire (black and white and Red (12volt switch). and then tie them in all together.
The way I was going to do it as take peiece of wire tab in to the 12 volt source (for the red wire) then every inch of so on that wire, take one of the guage wires and splice it in the 12volt wire.
Quick diagram I made for the 12 volt switch, The black and white wires would be hooked up in the same manner
I would NOT use any connectors at all use soder and heat shrenk. converted my 86 to 87-93 dash soder and heat sheenk though the hole car that I wired.
What you are doing will work fine with 18 gauge wire. 86foreye's recommendation to use solder and heat shrink is the best method for all types of automotive electrical connections.
