guage clusters
If you go into your cluster diagnostics mode you can scroll through till you get to "temp" and it will tell you in degrees Celcius what coolant temp is. As far as oil pressure..your car doesnt have a real oil pressure sender. It has a oil pressure switch that only gives u a constant reading. I would suggest adding a autometer "temp" and oil pressure gauge with new senders piggy backing your factory ones.
