H/C/I or s/c???
  • Thread starter Thread starter Fox 5.0
  • Start date Start date Jan 16, 2004
1 of 2 Next Last
F
Fox 5.0
23
El Dorado Hills/Riverside
Jan 16, 2004
  • Jan 16, 2004
alright, hope this isnt a repetative question, but here it goes...
Im getting a fox body 5.0, and i have two options:
1)i have a friend who has some trick flow twisted wedge aluminum heads, 1.6 rr's, and some pushrods he's selling for $800, so i could buy those, add the trick flow stage 1 cam, timing chain, trick flow intake, ARP head bolts, 24lb injectors, 255lph fuel pump, 75mm throttle body, MAF sensor and calibrate it for the injectors and then get a chip and tune...
OR
2)leave the engine stock... POSSIBLY get a rebuild... and throw on a vortech v-1 sc, run stock pulley and have like 6lb boost, get a 255lph fuel pump, 36lb injectors, bigger throttle body?, MAF sensor calibrated to the injectors?, chip and tune...
im partial to the blower, less work and having a s/c sounds cool...
any ideas?
billetunderwear
I've posted way more than my fair share of pointle
20+ Year Stangneter
May 14, 2002
1,148
Rohnert Park, Ca
Jan 16, 2004
  • Jan 16, 2004
If it were me I would go sc simply because you get a huge performance increase from just one modification. Then later on down the line if you decide to further modify the engine you get much bigger power gains. That's just me though.
drgn5.0
603
  • Jan 16, 2004
If it has forged pistons i'd go ahead and get a s/c, if it doesn't i'd do the other.
SmockDoiley
1,591
San Diego, CA
Jan 16, 2004
  • Jan 16, 2004
I'd say do the N/A approach for now since it will be a solid foundation for a future Supercharger. Do you really want to add that kind of air into your tired heads and such. Besides how many miles are on your head gaskets, and running stock cam and heads with stock valve springs wont allow you to fully see the potential of the S/C since your engine will want to die out at 4500 RPMs. Granted you will see power with a S/C, I feel it will be the same as bolting on a cam and heads. Plus you dont want to use a blower with those iron heads and inefficient combustion chambers when aluminum would allow you to run more timing for more power. A fresh set of aluminum heads with aftermarket head gaskets and ARP fasteners will be much better for S/Cing. Either way youll make power but the N/A stuff will be cheaper and give you the opp. to freshen up everything in the engine and prepare for a S/C later which will really flow with performance parts. Besides its best to capitalize on a good deal now because your friend wont have that stuff later after you install your S/C and want heads.
K
KickerStang
593
Colorado Springs
Jan 16, 2004
  • Jan 16, 2004
If you have enough for a s/c I would do that because it takes alot of scratch. Then when the money comes along get the h/c/i. As far as pushing air through ****ty heads/intake, it does not cost much to port them through tmoss. That would be good for the time being.
drgn5.0
603
  • Jan 16, 2004
I'd say either is good but go for the s/c, run that, then you will want more, do another motor and you still have a s/c to use.
mike keirstead
1,121
ROLLING A JOINT
Jan 16, 2004
  • Jan 16, 2004
I say H/C/I. I hate forced induction.
Do it the NA way man. It's alot more fun. I like beating up on the blown guys with my little 308.......some of them anyway
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Jan 16, 2004
  • Jan 16, 2004
h/c/i, it's always better to go NA before you 'charge it, that way you've got enough motor for the supercharger. Sure, with the SC you'll get lots of instant power, but if you had the h/c/i in place before you 'charge it, you'd see so much more. If nothing else, i'd spend the money on flow porting rather than the 'charger, and go natural.
Venom351R
4,548
41
98
MAINE
Jan 16, 2004
  • Jan 16, 2004
Fox 5.0 said:
75mm throttle body
You dont want to Put a 75MM TB on a N/A Application. Highest you want to go is 65MM. If you go w/ a Supercharger then go up to a 70MM. You would have to have one hell of a sick combo to even think about a 75MM TB.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jan 16, 2004
#10
  • Jan 16, 2004
  • #10
Yeah I would go 65mm....
Well I'm kinda in the same boat as Fox 5.0 about whether to choose a supercharger or go the N/A route...I'm worried about the timing and a/f ratio and messing with that going the supercharger route...but I know I want to get a rebuild or a DSSracing shortblock for sure...N/A or supercharger..that is the question
David
Venom351R
4,548
41
98
MAINE
Jan 16, 2004
#11
  • Jan 16, 2004
  • #11
5spd GT said:
I'm worried about the timing and a/f ratio and messing with that going the supercharger route...David
1. Adjustible Fuel Pressure Gueage
2. Boot Timming Controler.
Just do a safe tune well within specs of the "danger zone" and you will be fine. Supercharges dont cause problems, its the dummys who try to tune them and dont know what there doing and screw it all up.
F
Fox 5.0
23
Jan 16, 2004
#12
  • Jan 16, 2004
  • #12
Hey thanks guys for all the input... you all seem 50-50 though on what you prefer.. the thing with my friend, he has those trick flow heads, the rockers and the pushrods for $800 bucks... thats a good deal.. it just seems like theres more of "the little stuff" that you dont think about going with H/C/I rather than the s/c... geez what a dilemma! i have the money for a s/c no prob, i think i have the money for the h/c/i too... but i would like some left over money incase anything breaks so i can fix it... what do you think the difference between the two would be in cost... counting in the $800 for my friends stuff???
Jo_885o
422
Clint. Twp, Michigan
Jan 16, 2004
#13
  • Jan 16, 2004
  • #13
okay look at it like this s/c ur car now and make 300 to 375 rwhp on a safe amount of boost. Build ur car with h/c/i and then blow it and make 400 plus. You choose?
willys1
1,004
New Jersey
Jan 16, 2004
#14
  • Jan 16, 2004
  • #14
Either way you slice it,its comes up with "MORE POWER" aargh,aargh,aargh!
F
Fox 5.0
23
Jan 16, 2004
#15
  • Jan 16, 2004
  • #15
I think im gonna go the s/c route... seems a little cheaper, and like you guys say i can always do the h/c/i later... i dont need like 350+ hp, i just want a low to mid 13 sec car and i think a s/c, full exhaust, and gears will do that for me... but thanks all you guys for your input!! much appreciated!
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Jan 16, 2004
#16
  • Jan 16, 2004
  • #16
lol...hang on man...it's a long road ahead....nobody ever needs 350+ hp, you've just gotta have more and more and more....
N
needforspeed440
49
#17
  • Jan 16, 2004
  • #17
I think N/A cars are more impressive with good numbers than a s/c car. but whatevr floats your boat. Think evryone else covered everything.
JadeFalcon
1,924
Arlington, TX
Jan 16, 2004
#18
  • Jan 16, 2004
  • #18
first mod I ever did to my mustang was a blower, and then I slowly did everything else, and it was fun because mods that normall add a few horses to an na car added like 20 to mine at a time, real fun.
mike: Depending on what crowd you run with, N/A can only go so far on a street car, forced induction lets you go further.
1992blkGT
523
Beaverton, OR
Jan 16, 2004
#19
  • Jan 16, 2004
  • #19
That's funny, Ed Curtis recommended a 75mm throttle body for the N/A setup I was planning with him (302, AFR's, Edelbrock Performer, 80mm MAF, 24lb injectors, custom cam). He said 75mm will be best, but 70mm is also good. He wouldn't go any lower. You can argue with him about it, but I think he knows what's best for a N/A combo. 75mm would be fine, and then top it off with an 80mm Pro-M!
F
Fox 5.0
23
Jan 16, 2004
#20
  • Jan 16, 2004
  • #20
85_SS_302_Coupe - ha ha, i know what your saying... but at the same time the money i have wont last forever... so all that can come later, im in school at the moment so i dont have a lot of time or money on my hands you know? well thanks for the info and advice guys!
1 of 2 Next Last
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
T
  • Locked
Digital Tuning A9l issue or something else
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 11, 2025
