H-pipe help!!!
  • Thread starter Thread starter PhillyVert
  • Start date Start date Sep 19, 2011
P
PhillyVert
25
Philadelphia PA
Sep 19, 2011
  • Sep 19, 2011
Hey guys,i soaked the bolts on my stock h pipe for a day before i tried to remove it.So yesterday i try to take the header to h-pipe bolts off and they wouldnt budge.What size bolts are on the stock h pipe??I got all the bolts except the ones that connect to the headers off.Any tips for removing the sstock h-pipe???
Maryland Stang
1,656
30
39
Greenville, NC
Sep 19, 2011
  • Sep 19, 2011
I believe the nuts are either 9/16 or 5/8. After 20+ years they're usually so rusted on there isn't hardly anything that will take them off. You may try a torch to heat the nuts. I was trashing my headers when I removed my stock h pipe so I just cut the studs in half with a dremel tool.
P
PhillyVert
25
Philadelphia PA
Sep 19, 2011
  • Sep 19, 2011
Can i cut the studs without hurting the headers?And can the studs be replaced??
4rdnut
188
  • Sep 19, 2011
Buy an electric impact driver. I bought one from northern tools, chicago brand, orange in color, great for any nut or bolt on the car that won't loosen with a ratchet or wrench. Don't cut the studs because usually the stud will turn out with the nut frozen on the stud. If you can't get the nut or stud to turn out, cutting the stud will make it tougher to get the stud out after it has been cut. An impact driver will knock it loose.
stykthyn
5,232
2,652
223
gainesville
Sep 19, 2011
  • Sep 19, 2011
You can get new studs at Lowes. Look for automotive exhaust studs and buy matching nuts.
P
PhillyVert
25
Philadelphia PA
Sep 19, 2011
  • Sep 19, 2011
Ok my friends got one of those electric impact wrenches.I guess ill try that next.thanks guys
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
C
98 mustang keeps popping at idle like popcorn please help
  • Cannron
  • Aug 14, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 14, 2025
squeak93
