H&R Super Sports
No real way of getting around it unless you get the drag springs. Although having adjustable control arms and lowering the ride height in the rear helps as well as removing the front sway bar once at the track.
Otherwise, you'll have a decent handling car in the turns with the H&R just suffer a tad in a straight line launch because of the lack of wieght transfer.
I bought mine used so they were extra soft. If you want to buy used I got mine in the www.corral.net classifieds for $100 for all 4. If you want to buy brand new Autozone carries them. Should be around $140 for all 4 new. Make sure you get 4cyl Fox Body front springs and 8cyl Fox body rear springs. This should drop about 2 inches in front and 1.5 in back. Also will improve 60ft times. :nice:
That is "ZaC851" from here on stangnet. hes got the fox body springs.
