Hack job wiring
thestig
10
On my 88 it seems most of the electrical stuff just doesn't work. Most of the gauges don't work, the interior light under the dash is stuck on, the gauge lights don't come on, and so on. If I bought a good wiring harness off another car, maybe a new gauge cluster, and some new sensors, would this solve my problems?
I was also planning to go from carb to mass air. I have an engine harness from I think an 89 and an ECU from a 90. Does it matter which body harness I get?
There's no a whole lot to go on there.
It'll be tough to know is needed to fix that vehicle. If the accessories are in that bad of a shape and it's been converted to a carb, who knows what was done or what it will take to refurbish it.
There are differences in the wiring between 89 and 90 (air bag, etc).
It used to be a 4 cylinder car if that helps any
MASS air conversion instructions from Mustang Mass Air Conversion « FREE
A9L (5 Speed) computer from junkyard $100-$150
A9P (Auto or in a pinch, 5 Speed) computer from junkyard $100-$150
70MM MAF from 94-95 Mustang GT - $40-$70
MASS Air wiring harness kit $30-$85
The whole thing is probably less than $300 using junkyard parts.
A9L computers are 5 speed only
A9P computers are automatic, but will work with a 5 speed.
The conversion harness seems to work well for most folks. It avoids the compatibility problems in using a harness from the junkyard. Simple and cheap, actually less work that swapping the wiring harness.
Conversion Harness kits & parts
Interactive Systems & Technologies Mass Air Home Page
Ford Fuel Injection » EFI Harness Pigtails
If the idea of moving & soldering wires scares you, here's a list of compatible Mass Air wiring harnesses.
Copied from bbunt302
Just for reference, here's a list of all the compatible years:
89 harness should work for 86-89 as long as you're using mass air.
90 harness will only work in a 90. (B/c of air bags and dual dash connectors)
91 through early 92 harnesses should be compatible (single dash connector, fuel pump relay under driver's seat)
Late 92 through 93 harnesses should be compatible (single dash connector, fuel pump relay under the hood)
Larger MAF to go with Mass Air conversion:
94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a flange adapter to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes. *1 *2
*1.) Metal flange adapter Kurtz Kustomz Motorsports, Inc. KKM Buy the TR70 for $44.95. Or spend some time on eBay looking for one that may fit.
Try AutoZone and ask for 81413 - Spectre / 3 in. Aluminum Intake Mass Air Flow Sensor Adapter at $12.00. You may have to order it online.
*2.) MAF & sensor interchange
The 94-95 Mustang 5.0 MAF & sensor is also found on:
1995-94 Mustang 3.8L F2VF-12B579-A2A,
1994-92 Crown Victoria 4.6L F2VF-12B579-A2A,
1995-94 Mustang, Mustang Cobra 5.0L F2VF-12B579-A2A,
1994-92 Town Car 4.6L F2VF-12B579-A2A,
1994-92 Grand Marquis 4.6L F2VF-12B579-A2A,
Evidently the –A1A, -A2A, AA, etc. on the end of the part number is a minor variant that did not change the operating specs. You should be able to ignore it and have everything work good.
The Mass Air computers from 89-93 are interchangeable with a few exceptions. Just be sure you use the MAF & MAF sensor from the same series computer. The auto transmission computers use a different start circuit than the manual computers. You can use an auto trans computer in a 5 speed car with no problems or changes.I have done it in my original 89 Mustang GT, and I know it works OK. I have no positive input or com ments on using a 5 speed computer in an auto trans car. I personally would not do it.
The odd duck is the 93 Cobra computer, labled X3Z which is interally calibrated for 24 lb injectors. Try and avoid it if you can.
All the following are mass air unless they say Speed Density
8LD - MANUAL 88 5.0L Mustang Speed Density
8LF - Auto 88 5.0L Mustang Speed Density
A9L - 89-93 5.0L Mustang 5-spd
A3M - 93 5.0L Mustang 5-spd
A3M1 - 93 5.0L Mustang 5-spd
X3Z - 93 5.0L Cobra 5-spd
A9P - 89-93 5.0L Mustang Auto
A9S - 88-93 5.0L Mustang California
C3W - 89-93 5.0L Mustang Auto
DA1 - 87 5.0L Mustang 5-spd Speed Density
J4J1 - 94-95 5.0L SVT Cobra 5-spd
T4M0 - 94-95 5.0L GT Vert 5-spd
U4P0 - 94-95 5.0L GT Auto
W4H0 - 94-95 5.0L GT
ZA0 - 95 Cobra R
D9S - Lincoln LSC
