had my crank turned 10/10...what bearings do i need?
cenok is family
1,409
69
79
Norman, Ok
so yeah, i just got my crank back from the machine shop and they turned it .010. i don't know where to get the correct sized bearings. can anyone tell me or post a link to the correct sized main and rod bearings i need? and i want good bearings, clevite if possible. thanks a lot!
my crank is 20/20 and I got my Clevite 77 bearings at autozone. Here are the part numbers for mine:
Main Bearings
Mine are MS590P-20, so changing the "-20" at the end to "-10" gives you the part number you would need = MS590P-10 ($24.99 @ autozone).
Rod Bearings
Mine are CB634P-20,so changing the "-20" at the end to "-10" gives you the part number you would need = CB634P-10 ($2.99 @ autozone).
When you have a crank turned undersize, the coresponding bearings are then referred to as "undersize" as well, even though they are physicaly bigger than stock size bearings. Many people get confused and call them .010" overzize.
