  • 1994 - 1995 Specific Tech
Had My Timing Retarded Again!
  • Thread starter Thread starter DFG 5OH
  • Start date Start date Jan 18, 2006
1 of 2 Next Last
DFG 5OH
1,341
Louisville, KY
Jan 18, 2006
  • Jan 18, 2006
Well I've been having spark-knocking problems since i got my timing on my car fixed. When i got it, it was set around 0*, obviously the previous owner didnt know what he was doing and had the timing all ****ed up. I got it set to 10* (stock) and it had about 500 more HP, but pinged so bad it sounded like gravel in the cylinders. So i had it backed down to 8* and drove it like that on 89 octane gas for a while. I started noticing it pinging bad again, so today i had it turned down to 5*. I know the car isnt running up to full potential, and i would like to figure out why its pinging and fix it, so i can run at least 10* timing, and gain back the power i lost. So, what could be causing me engine to ping. Engine is stock, except for an MSD Cap/Rotor, some exhaust work, and FMS wires. The plugs are pretty new, motorcraft plugs, other than that all other is stock.
BTW the other day it was warmer outside, which caused it to ping worse, and when i got on it, and it would ping real bad, it would puff some smoke...
bill302
2,131
alabama,gadsden
Jan 18, 2006
  • Jan 18, 2006
is check engine light on? if it is or if it is'nt on, attempt to pull check engine codes and post results autozone does it free.
94Blue302GT
704
Chicago
Jan 18, 2006
  • Jan 18, 2006
lol, you're retarded....
Well, don't let it puff smoke, pinging is really bad.
Check you're fuel. If you have an aftermarket fpr, make sure it's at the correct pressure. you can pick up a bbk or something and then a guageto monitor it. Search around for the proper settings.
DFG 5OH
1,341
Louisville, KY
Jan 18, 2006
  • Jan 18, 2006
i had it looked at when the siming was set up a while back, no codes, fuel was perfect, maf is good...i'm really lost
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jan 18, 2006
  • Jan 18, 2006
run better gas, also try running some seafoam threw the fuel system and suck some into a VAC line to clean the intake a bit
94Blue302GT
704
Chicago
Jan 18, 2006
  • Jan 18, 2006
maybe the sensor on the distributor? The PIP i believe it's called. If you get a haynes or something, you can check to see if it's good or not.
DFG 5OH
1,341
Louisville, KY
Jan 18, 2006
  • Jan 18, 2006
i have seafoamed the engine/oil/gas already. I've tried all octanes of gas it pings at 87, 89, but not with 93 but it has NO power with 93 octane.
That PIP sensor is hard to replace, that would have to be a last resort.
bill302
2,131
alabama,gadsden
Jan 18, 2006
  • Jan 18, 2006
is this the exact plug your using gapped at .052-.058
Motorcraft ASF-32C F4 spark plugs
DFG 5OH
1,341
Louisville, KY
Jan 18, 2006
  • Jan 18, 2006
yes
BlackVert
5,589
9
98
Bethesda, MD
Jan 18, 2006
#10
  • Jan 18, 2006
  • #10
you are either gettng too much air or not enough fuel. so:
when was the last time you replaced the fuel filter?
do you have low fuel pressure?
is there a vacuum leak? carb cleaner spray at idle test? those tubes up under the intake can crack or come loose after 11+ years.
how many miles on the motor? carbon build up can decrease the combustion chamber size causing higer compression making it more susceptable to pre-ignition.
Kevin R.
473
Ohio
Jan 18, 2006
#11
  • Jan 18, 2006
  • #11
Funny Matt, I have had the EXACT same problem.
When I checked my timing, it was at 0*.
I bumped it up to 10*, and experienced pinging, very badly at WOT. I have ran better gas, but didn't work.
I put the timing around 8* as you did, and it still pings, not as badly, but at times.
I am wondering if running it at 0* for all those years made it so I cannot run it at anything but that? It is odd, and not worth messing up my engine over.
BlackVert
5,589
9
98
Bethesda, MD
Jan 18, 2006
#12
  • Jan 18, 2006
  • #12
good point. the computer may have adjusted for the timing being set so low. try setting it back to 10* and disconnecting the battery for 30 minutes. that will reset the computer so it will start learning again. then drive it around gently for a while to let it learn about your car before hammering it.
keep up posted
DFG 5OH
1,341
Louisville, KY
Jan 18, 2006
#13
  • Jan 18, 2006
  • #13
thats not a bad idea
GRGT1994
1,034
#14
  • Jan 18, 2006
  • #14
What would happen if someone had replaced a timing chain and was off a tooth, or the crank was just off TDC when installing the timing chain?
My guess is that your actual timing would be off of the indicated timing on your balancer. In that case, maybe an indicated timing of 0 is actually 12 to 16, and an indicated timing of 10 is over 20. Maybe that's what happened to you.
Don't know if my figures are anywhere in the ball park. But you get the idea. Anyway, just a thought.
95cobraguy
637
11
Concord, NC by way of LI, NY
Jan 18, 2006
#15
  • Jan 18, 2006
  • #15
u said it doesn't ping on 93 octane but has no power, why dont u run 93 octane and set the timing at 10 instead of 8. r u pulling out the spout connector when u set the timing?
warpd
44
Auburn,AL
Jan 18, 2006
#16
  • Jan 18, 2006
  • #16
yea try bumping the timing and running 93, I would think the loss in power with higher octane fuel would be because it is more resistant to igniting and with real low timing maybe the engine is having problems igniting the mixture.
Kevin R.
473
Ohio
Jan 18, 2006
#17
  • Jan 18, 2006
  • #17
keep up posted
Nice idea, I will definately have to try that!
Gotta start somewhere...
Kevin R.
473
Ohio
Jan 18, 2006
#18
  • Jan 18, 2006
  • #18
Also, does anyone know for sure if the computer can compensate over time for this?
Does it actually adjust to timing fluxuations? If so, what would be the point of the timing?
Are other engine functions besides ignition and the obvious timing effected?
I'm just having trouble seeing what the computer would compensate for. And if it did, then the timing would be pointless because the computer would adjust no matter what it was at...
jorge.pena
30
San Antonio,TX
Jan 19, 2006
#19
  • Jan 19, 2006
  • #19
If I remember right the computer will try to adjust timing because the oxygen sensors tell it the stuff coming out the pipes (exhaust) isn't right. But I don't know if it would actually get stuck there after a while. Have you run diagnostics on all your sensors, something like a bad throttle position sensor can really gum up the works . And to answer Kevins question, the point of timing is this. Those 10 degrees that everybody talks about is normally reffered to as base timing, and it is basically your timing at idle. This is a mechanical adjustment between distributor and piston (or crank) position, thats why you disconnect the spout so the computer won't interfere while you're trying to set it. 10 degrees means your distributor fires it's spark at 10 deg.before TDC, by the time the spark gets to the plug and the mix starts to burn the piston is at TDC (roughly). your timing does not stay the same all the time, when the engine starts revving up, the computer advances your timing accordingly, the higher the RPM the more advanced the timing. In non computer cars the timing is advanced via a vacuum controlled advance or a centrifugal one. This is done because the higher the RPM the faster everything moves (pistons are our main concern) but the gas air mixture burns at basically the same speed, and to compensate for that you have to fire the mix sooner.
Hope that helps.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jan 19, 2006
#20
  • Jan 19, 2006
  • #20
No
Grady
1 of 2 Next Last
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
  • brandyn200
  • Jun 20, 2026
AeroCoupe
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
