BlackVert
couldn't a very late spark cause the fuel to not burn, making the sensors report rich, causing the computer to pull fuel?final5-0 said:No
Grady
Grady
No you can't confirm, or no the computer does not compensate?final5-0 said:No
Grady
BlackVert said:couldn't a very late spark cause the fuel to not burn, making the sensors report rich, causing the computer to pull fuel?
GRGT1994 said:No you can't confirm, or no the computer does not compensate?
BTW, keep in mind with this discussion of timing that the computer dynamically adjusts timing based on sensor inputs, but only while the car is operating in closed loop. Once you hammer the throttle (WOT), the car reverts to open loop and uses preprogrammed fuel and advance curves (which are generally richer than in closed loop). I think that description is basically on, but maybe the computer gurus can clarify if I mucked it up too much.
Kevin R. said:Yes, but what I was asking was if over time if the computer would adjust to the timing being set at 0*, changing spark, fuel, etc. If it did, when set back to 10*, the readings would be off, via the computer.
But, I'm guessing the answer was "no"?
wytstang said:Matt the stock motocraft plug for our cars is ASF-42C the ASF-32c would be a colder plug to cold for your application imo. Have you pulled the plug to see what they're telling you?
final5-0 said:Kevin
If you set the spark at 7 with the spout out
and
Several weeks or months later you take the spout out and check it again
You should see 7 ... just as before ... when you set it.
Grady
xkuntrycowboyx said:misnomer??? ...sorry, im 'retarded' ... watcha mean.
