When I start the car, it sometimes will act as if the starter can not turn the engine over but then when I turn the key again it will turn over and start. The car runs perfectly and no white smoke for about one minute. But then the white smoke starts and lots of it. as soon as I start down the road the smoke will go away but the temp goes way up and then bounces up and down. Yes, it looses coolant. The oil looks fine and the compression checks out good. I guess the only way I'm going to know is to tear it down. Any suggestions? I'm concerned because this engine was bored .060 over. I was talked into this before I knew it was not a good idea. One other thought, I did change the heads to aluminum and re-used the ARP head bolts. Maybe I should have bought new?
