handling
  • Thread starter Thread starter meweehaa
  • Start date Start date Apr 5, 2004
First Prev 2 of 2
jikelly
20+ Year Stangneter
Jul 9, 2003
872
53
99
Lubbock Tx
Apr 6, 2004
#21
  • Apr 6, 2004
  • #21
1967coupe said:
When you change the strut rod bushings is a alignment needed afterwards?
Anyone know about this one?
LMan
1,246
Mom's basement
Apr 6, 2004
#22
  • Apr 6, 2004
  • #22
...not if you CAREFULLY marked the location of the rod and reinstalled EXACTLY where it was before. If you arent confident that you accomplished that, I would get it realigned.
I recommend paying extra for the 'lifetime' realignment...with a vintage Mustang, you'll be there at the shop fairly often
meweehaa
202
Northeast PA
Apr 7, 2004
#23
  • Apr 7, 2004
  • #23
Well I got the alignment done and yes it drives better but still as good as I had hoped. I did realize that the thing i had not changed were my sway bar to frame bushings. So after I do that hopefully it will be even better.
H
hunterhicks
62
D/FW
Sep 1, 2006
#24
  • Sep 1, 2006
  • #24
This thread is ancient, but I'll add my bit for those with this problem. I had a similar problem on my 66:
Change your strut rod bushings to rubber Moog ones- this completely changed everything on my car. Don't think about poly- makes it ride like a truck, and people say it breaks strut rods easier.
2bav8
2,511
Mesa, AZ
Sep 1, 2006
#25
  • Sep 1, 2006
  • #25
Wow, what an old thread...
Anyways, forget rubber and poly, go with a heim joint.
Far superior.
M
MitchGT
204
Sep 2, 2006
#26
  • Sep 2, 2006
  • #26
if you want to get the true picture of steering box slop, try turning the wheel while parked AND with the engine turned OFF. With the engine running the power steering hides the slop. Worn steering box plus power steering makes for an inconsistant handler. Mostly it seems ok, then on a turn it will not have the same reaction as the others, which can be a little scary.
SHIFTY101EASY
129
#27
  • Sep 2, 2006
  • #27
Far superior.
what is a heim joint? can u explain those a little?
H
hunterhicks
62
D/FW
Sep 3, 2006
#28
  • Sep 3, 2006
  • #28
It's works kinda like a universal socket- but is completely different.
you have unlimited movement with it- there is a inside piece encased in a chunk of metal- the inside piece is attached with a bolt to something, and then the rest of it can move as it wishes. check out my snazy new strut rods I just got from Rosehill performance:
http://www.hunterhicks.com/tech/strutrod.jpg
It's a bit hard to see, but it's the silver round thing inside the black support. When bolted in, it takes the place of the rubber strutrod bushings. Absolutely no unwanted movement like with rubber- this heim joint moves in all the directions the suspension wants to, and is always constant.
here is another one:
http://i14.ebayimg.com/03/i/00/92/bd/0c_1.JPG
2bav8
2,511
Mesa, AZ
Sep 3, 2006
#29
  • Sep 3, 2006
  • #29
Yup, that's a heim joint and it does wonders for your strut rod.
That and a set of roller spring perches will provide excellent grip while still providing a soft ride. Best of both worlds.
SHIFTY101EASY
129
#30
  • Sep 3, 2006
  • #30
do you need special strut rods for those or can u just throw them on the current setup on my 68? i would go look but its like 3 in the morning and im slightly tired....
2bav8
2,511
Mesa, AZ
Sep 3, 2006
#31
  • Sep 3, 2006
  • #31
You can modify your strut rods to accept a heim joint or buy aftermarket.
K
keith2172
Visalia, CA
Sep 8, 2006
#32
  • Sep 8, 2006
  • #32
Pics please, heim joint sounds interesting
Tim65GT
1,149
West Texas
Sep 8, 2006
#33
  • Sep 8, 2006
  • #33
here is a informative link on converting the strut rods:
http://home.bresnan.net/%7Edazed/adjustable
K
keith2172
Visalia, CA
Sep 12, 2006
#34
  • Sep 12, 2006
  • #34
Many thanks on ^^^ link, that shoud come in handy soon
First Prev 2 of 2
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Wheels-Tires Front end shimmy on 79 foxbody
  • 79fox2245
  • Jul 4, 2025
Fox 5.0 Mustang Tech Jul 7, 2025
General karthief
Drivetrain 1987 Mustang notch drive questions
  • Shannonfox123
  • Apr 12, 2026
Fox 5.0 Mustang Tech Apr 12, 2026
AeroCoupe
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
