Happy Birthday 1990Coupe!!
Thanks guys :)
Been going through alot of stuff at home so this made my day haha.
Unfortunately i managed to strip a bolt installing my cobra upper... im rather annoyed but i hope its not too bad and will leak, we'll find out when i fire it up!
Stripped bolt? Dammit. You know I had to pull my Cobra intake off my old 91 GT for an oil leak. While putting it back together I managed to strip and break a bolt off in the lower. The bolt is what held the fuel rail in tight, which in turn held the injector o-rings in tight to the lower intake. I fired it up and fuel leaked everywhere. Had to take it all back apart. I then broke an easy-out off in the bolt that I drilled a hole in. So I ended up obloning the bracket in the fuel rail drilled a new hold in the intake tab and then put a self tapping bolt in there. Worked perfect....but what a PITAAAAAAAAAAAAAAAA...
