hard clutch
  • Thread starter Thread starter speedwolf94
  • Start date Start date Jul 26, 2009
speedwolf94
  • Jul 26, 2009
i got the car a little while ago and the stock clutch quadrant broke on me, but after gettin a billet one it works great but it just seems like the clutch is really hard... when i got the car the guy said it has a stage 2 clutch in it. when i press it down i have to use my whole leg to push it in and after a while my foot gets sore and i wasnt sure if its like that with a stage 2 clutch or something is not right
67coupe
658
402
93
Huntsville, AL
Jul 26, 2009
  • Jul 26, 2009
Sounds like a sticking clutch cable.
If you have anything other than a Ford or Maximum Motorsports cable, I would look there first.
HISSIN50
34
129
Jul 26, 2009
  • Jul 26, 2009
Agreed. Most likely a clutch cable issue. Cheap ones can bind really badly.
speedwolf94
  • Jul 26, 2009
i know when i put the new clutch quadrent in, the clutch cable slid back and forth by hand when it was out of the car.. im not sure if it could make a difference when it is all hooked up. they guy i bought the car from said that since its hard cause it has a stage 2 clutch but it just feels to hard.. im not sure if it could be the clutch or something
HISSIN50
34
129
Jul 26, 2009
  • Jul 26, 2009
A crappy cable will slide easy with no tension on it. Toss in some tension and some heat (headers) and it can feel like trying to push the pedal through quick sand.
Clutch manufacturers are congizant of pedal pressure. They generally keep diaphragm pressure on the lighter side, instead changing the friction materials to increase hold (often with the side effect being a more abrupt engagement). The heaviest pedal I've felt is a HD Ford clutch and it sounds like it's nothing compared to what you're feeling.
speedwolf94
  • Jul 26, 2009
sounds like thats what the problem is. i know i have a new one from autozone for it but it is the same one just new.. i would probly be better off and spend the money on a better quality one? got any that would be a good cable for a good price? cause im tired of having to put all my force just to put the clutch in.. makin me not fun to drive and not want to drive it
clement
1,104
52
59
Oak Cliff
Jul 26, 2009
  • Jul 26, 2009
might want to check it to make sure. one of my friends cars once had this problem. we figured out it was the pressure plate taking a dump after it pushed all the thrust out of a fairly fresh shortblock.
67coupe
658
402
93
Huntsville, AL
Jul 26, 2009
  • Jul 26, 2009
You have one from Autozone installed on the car now? If so, this is definitely your problem.
If you still have the factory cable, use it. If not, you'll need to find a Ford OEM cable. Try the dealerships or Maximum Motorsports :: The Leader In Mustang Performance Suspension
Some good info here:
Where to buy Ford factory clutch cable? - Page 2 - Corral Forums
EMW150
2,020
Roaring Spring,PA
Jul 26, 2009
  • Jul 26, 2009
Most of the time this is caused by a misrouted cable. Look at it from the front. Should pull on a straight shot. I've seen guys route them on the wrong side coming through the k-member and puts the cable on a bind. Check it.
speedwolf94
#10
  • Jul 26, 2009
  • #10
i got a new one from autozone but i havnt put it in yet, the way i have it right now, the cable keeps coming out of the little holder piece thats by the engine, if i put it in it is a little bit harder but when i pops out it makes it a little easier but its still very hard. it does sound like the pressure plate could be the problem. even when the car is off and there is no heat to it, it is very stiff..
HISSIN50
34
129
Jul 26, 2009
#11
  • Jul 26, 2009
  • #11
No matter what, you're going to want a ford cable (be it an OEM replacement or the MM cable), so you might as well order one and try it.
Popping out of the locating bracket sounds like there is a lot of torque on the cable (read binding).
speedwolf94
#12
  • Aug 10, 2009
  • #12
finaly got the clutch cable here and got it put in, and it works amazing! wanted to thank u guys for the help, now i can actually enjoy driving my car
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
Engine Which fan clutch ?
  • AnthonyA1234
  • Jun 22, 2026
Fox 5.0 Mustang Tech Sep 19, 2026
Mustang5L5
R
Drivetrain Clutch
  • Robman8028
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jul 2, 2025
AeroCoupe
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
