  • SN95 4.6L Mustang Tech
Hard Starting
  • Thread starter Thread starter Saleen Guy
  • Start date Start date Aug 17, 2004
Saleen Guy
33
  • Aug 17, 2004
Hey Guys, Just got my motor finished and in its running good except when i try to start it sometimes. Its hard to get going, well atleast not like it was before. I need to give it a bit on the throttle to get it to fire and run. I was told this is because the injectors are leaking through and fludding the cylinders. The crappy thing is they are new so if thats the case im not impressed. Well any ideas would be apreciated.
Thanks
Black_Cobra
80
Boston,MA
Aug 17, 2004
  • Aug 17, 2004
The injector idea sounds like a wild guess. If it were leaking fuel then I would expect a black puff of smoke once it starts. No?
My wild guess is ignition timing.
I'd give the folks that worked on the motor a call, see what they say.
...good luck.
Green Flea
28
California
Aug 17, 2004
  • Aug 17, 2004
I think this is a pretty common problem. Mine has done this since it was new. It does it about once a month, no big deal. I think it has to do with the fuel getting vapor lock in the line. Dunno how frequent yours is though. If its every time you start then yeah somthing is probly wrong.
Saleen Guy
33
  • Aug 18, 2004
Yup black smoke is present, On these stangs the ignition timing i believe is controlled by the computer so i would not guess that and the fact that my check engine light has not come on. Hmm Well Keep on looking into it i guess.
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
  • Gulftown980x
  • Jul 29, 2026
squeak93
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
