Hard to find Brake part
  • Thread starter Thread starter taborjoshjlt
  • Start date Start date Jun 7, 2009
T
taborjoshjlt
  • Jun 7, 2009
I am trying to find this part for my break line, i have searched every sight there is and i still cant find it , in this picture http://www.hg80design.com/Christine/Files/65disc.jpg it is part number 4022 that i am missing, is there a substitute for it?
2+2GT
3,333
10
79
Southeastern Pennsylvania
Jun 7, 2009
  • Jun 7, 2009
You must have the wrong catalogs. Glazier's has them, the single exhaust bolt is their G06156, and the dual exhaust bolt is G06177. The difference is the length, the single exhaust had the brass block on the the housing, requiring a long bolt, while the dual exhaust had a steel bracket on the housing, using a much shorter bolt.
hotcobra03
poteet,tx
Jun 7, 2009
  • Jun 7, 2009
if thats the banjo bolt than most parts store will not have it...
for hard to find stuff try granigers
D
D.Hearne
11,730
south louisiana
Jun 7, 2009
  • Jun 7, 2009
That's really not a bolt, it's got two functions, one is the bolt to hold the junction block in place, the other is it's also the rear axle vent tube. You can find these at a junkyard.
2+2GT
3,333
10
79
Jun 7, 2009
  • Jun 7, 2009
It's not a banjo bolt, it's a hollow bolt, to connect the axle vent hose.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jun 7, 2009
  • Jun 7, 2009
If you look at the diagram is sure does LOOK like a banjo bolt. The diagram is decieving. The rear brake line does not have a banjo bolt, the hard line attaches directly to it on both sides and then runs along the axle. That bolt is actually the axle breather tube which goes through the brake line's distrobution block and holds it to the axle. I'm not sure what thread type this uses, but you might be able to use a brass NTP fiting. Junkyards are another option. I don't know if the current breather tube's on the 8.8s use the same threads or not but you can always try geting one from a dealership and if it doesn't work just return it.
Wart
I'm Mad as HELL and I'M not Gonna Take it ANYMORE!
408
NE Ohio
Jun 7, 2009
  • Jun 7, 2009
Lets play Wheres Waldo.
I've seen these in different "bolt" lengths with nipples for different breather tube diameters. I would be hard pressed to think of a Ford rear axle that does not have one, including trucks. Far as I know Ford didn't use a hooded axle breather bolt.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Jun 7, 2009
  • Jun 7, 2009
National Parts Depot has them, also under part number 4022 in various lengths. All it really is is a hose barb with straight threads.
I do think that Ford used hooded vent bolts, but The only cars I have really noticed them on were from the late '50s.
Mil1ion
48
  • Jun 8, 2009
Axle Vent C5ZZ-4022-B
D
D.Hearne
11,730
south louisiana
Jun 8, 2009
#10
  • Jun 8, 2009
  • #10
+1
I've got a couple of 9" pickup rears that don't have em. When I did the 9" for my Comet, I used a pipe nipple for the vent hose and welded a stud on for for the brake junction block.
Melling M-10687 Green Spring
  • AeroCoupe
  • Aug 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
AeroCoupe
D
After Market fuel rails with Stock fuel lines
  • dropteeth
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
2000xp8
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
