  • SN95 4.6L Mustang Tech
Hardballer or Trick Flow
  • Thread starter Thread starter BLKsteeda
  • Start date Start date Jun 2, 2008
BLKsteeda
236
Anywhere
Jun 2, 2008
  • Jun 2, 2008
I'm in the market for buying an intake for my 01GT. I'm N/A with full bolt ons, ported heads and cams...I'm looking for results and opinions with either of the intakes, performance gains, etc on a N/A car. When I spoke with Trick Flow they said around 25rwhp with my mods. Anyone have personal experience with either?
Thanks
2000fordstanggt
404
Westland, MI
Jun 2, 2008
  • Jun 2, 2008
Thanks
i say hardballer all the way
heres where mine came from-
http://www.texashotrods.com/storefrontprofiles/DeluxeSFItemDetail.aspx?sid=1&sfid=70952&c=90648&i=222304916
superstang01
448
9
29
Kingston, On, Canada
Jun 2, 2008
  • Jun 2, 2008
did it make a difference on your bolt on car?
BLKsteeda
236
Anywhere
Jun 2, 2008
  • Jun 2, 2008
I'm curious as well if it made a difference on your car as you have minimal mods...any dyno numbers?
H
H0SS302
34
  • Jun 2, 2008
harballer all the way. u will not see gains worth the price IMO for an n/a car. to feel gains u would need something along the likes of a p51.
what the hardballer offers is a bulletproof intake for nitrous setups.
what most ppl dont realize is the stock PI intake flows extremely well, thats why u dont see much difference in #'s. the only reason to upgrade would be if ur running a healthy shot of giggle gas, or your intake cracks and u need a new one.
BLKsteeda
236
Anywhere
Jun 2, 2008
  • Jun 2, 2008
See and I heard completely different from trick flow about their intake on a N/A car with ported heads and cams...they said 20-25whp is very likely
H
H0SS302
34
  • Jun 2, 2008
im sure you will see more gains vs a non ported h/c car.. but i doubt ull see more than 15RWHP.
hell, with h/c/i on a 2v GT your only looking at ~40-60hp putting you at around 320's with full boltons. of course all this is relative to the specs of ur mods; just an example.
FoxRod87
243
Carolina
Jun 2, 2008
  • Jun 2, 2008
Did you have any issues when you installed it?
H
htxfastlife
14
  • Jun 3, 2008
i have tf intake, i bought it cuz my stock intake cracked and caused a blown head gasket. i had heads- cams put in at the same time and the guy who did the dyno said i would of been better off with the pi intake, cuz i lost some hp. something about gettin to much air... and once i get a blower then i will see better results.
oxfordgt
288
Clarksville, TN
Jun 4, 2008
#10
  • Jun 4, 2008
  • #10
I have the TF and it does exactly what I bought it for. It makes power across the band with a boost above 4000rpms. I have stock heads and cams and I am running 7.8 in the 1/8 when I was running 8.6 before. Also installed elec wp, megabite jr lower control arms and sniper tuned at the same time as the TF.
FoxRod87
243
Carolina
Jun 4, 2008
#11
  • Jun 4, 2008
  • #11
How is the belt routed with an electric water pump?
oxfordgt
288
Clarksville, TN
Jun 5, 2008
#12
  • Jun 5, 2008
  • #12
Same as stock. It has an idler pulley on it.
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
