Let's say just for the sake of discussion that I just have budget for one set of torque boxes - which ones should go in first, upper or lower? Both have been seam welded already and were in great shape to start with.
Also, Delrin, poly or spherical bushings on the chassis side on BOTH upper and lower, or one or the other?
'88 coupe, track only, about 3,000 lbs., no more than 375 Ft./Lb., footbrake stall, 3500 stall converter, 3.55 gear, 9" slicks, 10pt. with welded, through the floor subfame connectors.
Opinions?
Opinions?
Sounds like you've been there done that...uh??
