Harmonic balancer????? wobbly????
  • Thread starter Thread starter btsclan
  • Start date Start date Jun 16, 2008
btsclan
64
Seattle, WA
Jun 16, 2008
  • Jun 16, 2008
Well this is strange, lately when I have been driving my stang on the highway at speeds over 60 I am getting weird vibrations and shutters from the car when I press the gas, I thought this was due to the fact that some a-hole on their cell phone cut me off and I got some flat spots on my tires when I braked so hard.....but today I noticed that my harmonic balancer is wobbling. I take it this is a bad thing and that it needs replacement? Also could this be causing the vibration? When the car idles it rattles a little but not too bad and I can rev it up without any vibrations,
So I take it I need to replace my harmonic balancer because its not normal to wobble like that!
Fast63
717
  • Jun 16, 2008
You better start hoping it is just the balancer, because normally a wobbly balancer means your crank is broken/bent.
Maryland Stang
1,656
30
39
Greenville, NC
Jun 16, 2008
  • Jun 16, 2008
The balancer is just coming apart. It happens a lot. Just replace it.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Jun 16, 2008
  • Jun 16, 2008
Hopefully you solve the problem. IF it is wobbly, replace it right away. That thing falls apart, you not only need to buy a balancer, you need a belt, a crank pulley, possibly a cooling fan and radiator, if it damages that stuff and a tow home....not cool man. Get it done right away.
mustangfan1990
505
Lenoir, North Carolina
Jun 16, 2008
  • Jun 16, 2008
running into the same problem but I think my crank is done due to overtightening the SC belt
9
95ConvGT
65
Norfolk,Va
Jun 16, 2008
  • Jun 16, 2008
You say its wobbling. They all look Wobbly just looking at them. You need to see if the rubber has come apart or the balancer has shifted. Mine in my old vert did the same thing. It took me about a month to chase that problem down but i had very odd symptoms. Once i put it on and fired it up and it ran perfect i was so relieved.
H
HaynStang
124
Portland
Jun 18, 2008
  • Jun 18, 2008
The rubber on the stock balancers can crack causing the two sides of the balancer start to come apart, it will look like the balancer is wobbling with the engine running. In my case it looked slightly wobbly and caused minor vibrations at idle, but smoothed out with more RPM. Once I pulled the balancer I could see that it was shot, I put a new balancer on and it cured both issues.
I went with a Professional Products balancer which works great, you can also get a new stock replacement, both are under $100. You'll need to rent some special tools to remove and install the balancer but it's not to difficult to do.
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
U
8 Years of Vibration leading to engine knock?
  • UpgradeXP
  • Apr 14, 2025
SN95 V6 Mustang Tech Apr 14, 2025
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
