  • SN95 4.6L Mustang Tech
Has anyone installed SFC's themselves?
  • Thread starter Thread starter JetBrett
  • Start date Start date May 8, 2006
JetBrett
384
Sammamish, WA
May 8, 2006
  • May 8, 2006
I've got all of the equipment to install a set of UPR subframe connectors, except for a lift. Has anyone installed these using jackstands and if so, how did it go. I'm concerned since Maximum Motorsports is pretty clear that a lift should be used and that the car's weight should be on the tires. Is this overkill, or will welding these while the car is on stands screw it all up?
D
DerekStangGT
My package is in the mail!
Feb 18, 2003
1,068
May 8, 2006
  • May 8, 2006
do not install them on jackstands!!!!! it MUST be on a rack where the weight of the car rests on the tires, not even a lift!!! when the car is on a lift or jackstands, the weight of the body falls on the lift points. the suspension is maxed out. that is how the car will always ride if you tie the body together with SFCs in the air. very very bad idea. pay for the install
R
RoadconeTuning
458
Upstate, SC
May 8, 2006
  • May 8, 2006
you could get all the tires on cinder blocks...
hognutz
1,940
albany, oregon
May 8, 2006
  • May 8, 2006
I would not personally use regular cinderblocks. it is possible for them to break. you could buy some ramps and just jack the car up onto the ramps.
the car should be sitting on all four tires when they are installed. if you can't do this i would take to somewhere and have it done.
tomustang
Psychotic Member
3,434
McLean Hospital
May 8, 2006
  • May 8, 2006
I did mine one side at a time, jacked up under the front spring cup, and the axle
also welded up a nice crack on the driver side tq box too
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
May 9, 2006
  • May 9, 2006
cinder blocks work fine.
Black Stang 97
the guy on top of me is funny
Nov 11, 2004
483
Los Angeles, CA
May 9, 2006
  • May 9, 2006
so you shouldnt do it on a lift??? i think i learned sumthing new today.....
tomustang
Psychotic Member
3,434
McLean Hospital
May 9, 2006
  • May 9, 2006
Idiot. Don't post stupid **** like that, this isn't the SRT forums.
Black Stang 97
Nov 11, 2004
483
Los Angeles, CA
May 9, 2006
  • May 9, 2006
tomustang said:
Idiot. Call me when one breaks
tomustang
Psychotic Member
3,434
McLean Hospital
May 9, 2006
#10
  • May 9, 2006
  • #10
Black Stang 97 said:
Stang|ess
Oct 18, 2003
941
Hawaii
May 9, 2006
#11
  • May 9, 2006
  • #11
It was done on cinder blocks and none broke. Good job on the name calling, real mature.
And it's fine on a lift as long as all the wheels are supported.
^ bad.
^good.
tomustang
Psychotic Member
3,434
McLean Hospital
May 9, 2006
#12
  • May 9, 2006
  • #12
name calling? it's TRUTH buddy. idiotic advice, just as bad as telling someone to start the engine while someone holds a wrench to take off the crakshaft bolt.
worse in point, people have been hurt for doing the crankshaft idiotic move, but the several have DIED from using bricks/cement blocks as substitute jackstands
Stang|ess
Oct 18, 2003
941
Hawaii
May 9, 2006
#13
  • May 9, 2006
  • #13
So you're suggesting people use jackstands to weld in SFCs?
Shiroelex
There's nothing worse than aut
728
Westland, MI
May 9, 2006
#14
  • May 9, 2006
  • #14
No, he's trying not to get someone killed for using cinderblocks to put their car on.
F
flexiclese
85
Pearland, TX
May 9, 2006
#15
  • May 9, 2006
  • #15
I did mine the same way as tomstang 3-4 yrs ago, not a problem
I found it somewhat easier to use a floor jack to apply a "little" pressure to the SFC to hold it into place before/during welding, emphasis on little pressure
on a side note, I purchased Kenny Brown SFC's, and they came crooked, I had to heat them with a gas torch and blend them back, don't buy from them
R
rpburnette
152
Tampa, FL
May 9, 2006
#16
  • May 9, 2006
  • #16
The point here is to support the car by the wheels not the frame and no matter how you do it, just make sure you are safe.
I installed my sfc on my own and had no problems besides it being a pain welding with the car sitting about a foot from the ground, I should have jacked the car up higher.
Oh, when welding, go slow, and allow each weld to cool a little. Remember, the carpet is on the other side of the floor pan, so you don't want to heat up the floor pan too much and burn the carpet.
Good luck
tomustang
Psychotic Member
3,434
McLean Hospital
May 9, 2006
#17
  • May 9, 2006
  • #17
Good luck
good key point, another is to sheild any exposed lines so they don't get hit with the spark
04gtdrop
532
Sac, CA
May 9, 2006
#18
  • May 9, 2006
  • #18
speaking of SFC's... does anyone know of a good local place in Sacramento, CA that could weld them in for me?
JetBrett
384
Sammamish, WA
May 9, 2006
#19
  • May 9, 2006
  • #19
Thanks for the replies all. I think I'm going to try it using ramps.
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
F
Getting my old autocrosser running again
  • flightops
  • Aug 28, 2025
  • The Welcome Wagon
The Welcome Wagon Aug 28, 2025
